Fuel filter change Question
Old Oct 5, 2010 | 01:05 PM
whisler's Avatar
whisler
After checking threads on here and checking a Chiltons manual, I changed the fuel filter on my 1989 F250 4x4. All went well except for one strange thing. Tried to relieve pressure at the Schraeder valve on the fuel rail and there was no pressure. When I took the lines loose from the filter there was no spray-out, just gas running out of the lines as would be expected. The truck has been sitting for several days. Is this lack of pressure in the fuel line indicative of another problem that I should check for, or is it natural to loose pressure when not in use for several days?
Old Oct 5, 2010 | 02:31 PM
fordyduty's Avatar
fordyduty
It is normal for the pressure to bleed down overnight.
Old Oct 5, 2010 | 02:36 PM
ExtrmZ's Avatar
ExtrmZ
yeah turn the key on to prime the fuel rail, then press the schrader valve and it should have pressure
