Blower motor issues. Relay upgrade?
Old Feb 10, 2017 | 09:50 PM
Montync's Avatar
Montync
84 f150 ...I am working on my heat and air setup. My blower motor is droping my voltage down .5 and putting a heavy load on the alternator. I have tested 2 same thing with both. Is there a way to add a relay, heavier guage wires and have a high and low setting? Is there a way to get it to blow stronger? And yes the system has been cleaned out. On high it feels weak out of the vents. Searching I see people talking about relay mods but dont show or realy go into detail how to set it up.
Old Feb 10, 2017 | 10:02 PM
ChRoNo16's Avatar
ChRoNo16
Is it a relay issue? or the wrong alternator? also what size fuse is in the spot?
Old Feb 10, 2017 | 11:49 PM
Montync's Avatar
Montync
I was wondering if a relay would help it blow stronger. The alternator is a 3g 130 amp alternator. As far as the fuse I think I may have accidentally put in a 15 amp fuse.. I think it needs 30. I will check in the morning
Old Feb 11, 2017 | 12:45 AM
timbersteel's Avatar
timbersteel
I would be interested in adding a relay for the blower motor on our trucks.
Even with my 3G 130 amp alternator, it taxes my electrical system.
I also have a relay for the headlights so it doesn't tax the electrical system.
Old Feb 11, 2017 | 08:01 AM
Montync's Avatar
Montync
I might upgrade the blower to a gm style 1 wire blower motor and run a ground wire from the battery straight to the plate. If its going to tax it like that Id rather have a blower that can at least blow out a candle on high.
Old Feb 11, 2017 | 10:23 AM
Lead Head's Avatar
Lead Head
If the blower is pulling your system down that much, it's probably working hard. You likely have vacuum or cable actuator issues blocking the air flow.
Old Feb 11, 2017 | 06:03 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The blower always has key on power, speed is regulated through the resistor pack to ground.
A relay will take the blower load off the dash wiring, but making sure there is a good ground path from switch to -- cable can never hurt.
Weeks77
Large Truck
Dec 3, 2024 09:50 AM
thingsreef
1997 - 2003 F150
Sep 8, 2018 10:43 PM
animal45
Escape & Escape Hybrid
Dec 9, 2012 07:50 AM
CABGx3
Aug 3, 2010 10:13 PM
