Sponsored by: Real Truck
Shocks - When to replace
Old Feb 9, 2017 | 09:29 PM
BOHAWG175's Avatar
BOHAWG175
2012 6.7, 4x4, SRW, 4" Lift, 35" Tires with 180,000 miles. Question I have is how do you know when it's time to replace the shocks. Mine are original and I don't seem to notice anything that would tell me that they were worn out but it just seems like with that many miles that they would be due. almost all highway miles with around 30,000 miles of towing any where from 2,000-10,000 lbs.
Old Feb 10, 2017 | 06:31 AM
Slowpoke Slim's Avatar
Slowpoke Slim
Are these shocks original to the truck, or just original to the 4" lift?
Guys are reporting their OEM shocks dying at 30-50K miles, give or take.
My truck has just (barely) under 40K miles on it now. I'm planning on doing my shocks this spring, before our first RV trip.
Old Feb 10, 2017 | 07:30 AM
snowdog79's Avatar
snowdog79
With that many miles, I would bet they are worn out. Seems like the OEM shocks barely last 50k, if that, before they need to be replaced.
Old Feb 10, 2017 | 07:34 AM
stufarmer's Avatar
stufarmer
Today is a good day to replace them. Typically Fords O.E. Shocks loose there Re-Bound by 50,000 miles. I do know that when you replace them your truck it will feel like a difference vehicle. I believe the general concences here are either Bilstein 4600/5100's or Rancho 9000's as replacement choices.
Old Feb 10, 2017 | 08:27 AM
Copper.Farm's Avatar
Copper.Farm
i vote for Fox 2.0 with reservoirs - a very nice ride and rebuildable.
Old Feb 10, 2017 | 12:37 PM
BOHAWG175's Avatar
BOHAWG175
These are the originals from the factory. I used a Readylift and did not have to change them out when I did the lift. Bilstein 5100's seem to be the most favored so I think that is what I will go with once it warms up a bit and I can get out and change them.
Old Feb 10, 2017 | 04:04 PM
Agro's Avatar
Agro
I changed my shocks on my 2012 F-250 on 12/27/2016. Truck had 86,000 on it, and every single shock, including the steering stabilizer shock had zero rebound. I pushed them in and they stayed in. One shock, (drivers rear) would grind as i moved it in/out.
I wouldnt be shocked if they were shot in under 10k. They suck, they arent even Rancho's from the factory, they are FoMoCo with a rancho sticker. POS's.
Old Feb 10, 2017 | 04:28 PM
Kdr358's Avatar
Kdr358
My First set of original shocks lasted 18,000 miles, I was able to get them replaced under warranty, second set lasted until 48,000 miles, so 30,000 miles out of that set.
I replaced them with Bilstien 5100's along with the stabilizer. They really improved the ride.
Old Feb 10, 2017 | 06:34 PM
fordman19762003's Avatar
fordman19762003
My truck has 42k on it and I plan on replacing the shocks this spring.
Old Feb 10, 2017 | 06:37 PM
Agro's Avatar
Agro
It was a pleasure on my 2012 (same as yours). Didn't take any wheels off, could probably be done without a floor jack, no special tools, etc. DIY at home, 1 hour if you have done it before and know right what to do.
RM2738
6.4L Power Stroke Diesel
Sep 13, 2014 10:50 PM
Ian123
Jun 27, 2012 09:00 AM
tperk100
Feb 7, 2011 06:15 PM
SturgeonHunter
Sep 11, 2010 12:29 AM
sray1027
1997 - 2003 F150
Jun 4, 2004 05:51 AM
