engine swap??????
Old Feb 9, 2017 | 02:57 PM
mrxf350's Avatar
mrxf350
engine swap??????
is it possible to install a 390fe with c6 tranny in a 95 f150 4.9 auto?
its not going to be a daily driver just a weekend cruiser and street racer.
I want to humiliate some chevy fans where I live. Do I have to use any of the wires from the computer? I'm gonna have a fuel cell so no need for the stock tanks with the in tank fuel pump. There isn't any emission tests here.
Old Feb 9, 2017 | 03:14 PM
Mudsport96's Avatar
Mudsport96
Well, anything is possible if you can fabricate. Weld, grind, etc... The FE series never came in these trucks obviously, so you will have to make all of your own mounts. Then your own fuel system, and I doubt any off the shelf headers will work, so youbwill have to make your own.
Old Feb 9, 2017 | 03:45 PM
R&RFord's Avatar
R&RFord
If you have the fabrication skills and are just treating the 95 as a shell more or less I suppose it wouldn't be that much worse than swapping in any other engine/trans combo.
It seems to me that it would be easier to hop up an engine that came in these trucks and install that, or even easier find a truck with a the engine/trans combo of your choice already in it and spend your time and money on the power train and not on the swap.
Old Feb 9, 2017 | 08:28 PM
Lead Head's Avatar
Lead Head
It'd be much easier to swap a 351W in.
I'm not sure a 390 in front of a C6 is going to be humiliating much either, especially if it's a truck motor.
tmcalavy
May 18, 2011 07:31 PM
xman7896
Mar 12, 2004 01:14 PM
ford racer 02
Dec 21, 2001 10:25 AM
79supercab4x4
Apr 26, 2001 11:15 PM
