302 4-spd to 390 C6 engine swap
on
Depends on what engine/tranny were in the truck before....if the same type then the mounts, driveshaft,etc are fine...if not you will need engine mounts, towers, may be able to use the old trans crossmember, driveshaft may have to be adjusted for length, rad,exhuast manifolds..........there must be more.
Alot easier if the truck formerly had an FE/C6 combo. May even have to get new front springs depending on how much the front drops.....FE's are quite heavy
steveo24
22
09-01-2009 02:12 PM
blue76
04-17-2007 12:17 PM
Twisted 67
02-25-2003 09:38 PM
