Cab Design for Transmission
Old Feb 9, 2017 | 01:41 PM
Arbiter's Avatar
Arbiter
Question Cab Design for Transmission
Curious question for the enlightened.
In another post about transmission swaps, a person made mention that the 4WD cabs came with a higher/taller transmission hump than the 2WD ones. Does anyone know if there is any truth to this?
Old Feb 9, 2017 | 01:51 PM
good to doo's Avatar
good to doo
There is.They can be used with some mods. Way easier to do before you put the cab on. Its the tcase that has the issue with clearance. Are you using a 2wd cab on a 4wd, then you have to mod it. If the other way around no problem.
Old Feb 9, 2017 | 02:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Also believe 2wd trans hump cover is not removable, and 4wd is, for sure. And yes there is a height difference.
Old Feb 9, 2017 | 03:14 PM
tndallas's Avatar
tndallas
My 77 2wd transmission hump is removable.
https://www.ford-trucks.com/forums/9...nny-humps.html
Old Feb 9, 2017 | 03:18 PM
77&79F250's Avatar
77&79F250
That is why I said "I believe"..kind of like a guess. Thanks for the correct answer, and now we all know.
Old Feb 9, 2017 | 04:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Feb 9, 2017 | 04:22 PM
JakeHan's Avatar
JakeHan
So......Is the cab shell actually different, or is it all in the center pan (as in, keep the center pan out of your old cab?)
Old Feb 9, 2017 | 04:53 PM
77&79F250's Avatar
77&79F250
I am going to say, no not the shell, yes just the floor pan.
Old Feb 9, 2017 | 06:15 PM
JakeHan's Avatar
JakeHan
Floor pan as in the removeable one, I guess it's the "transmission cover" in numberdummys parts page? Sorry to be a bother, I have a nice '74 2wd body that I'm trying to find a 250 4x4 frame for, was thinking it was going to be an easy body swap - making sure that's the truth....
Old Feb 9, 2017 | 07:17 PM
Steven@nd's Avatar
Steven@nd
My 74 F-100 2wd has the "high" transmission hump that is removable. I think it's part of having the C6 transmission...
Old Feb 9, 2017 | 07:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There are basically two transmission "humps" in these trucks. They're often referred to as "high hump" and "low hump versions. You'll see this when you look at replacement carpet.
It's really simple. In the low hump trucks, the transmission tunnel is one piece and not removable. These are 2WD only. The high hump version has a removable tunnel. These are 4WD AND 2WD.
I don't think there was any rhyme or reason in the way Ford determined which 2WD truck got which floor pan. My '73 F100 2WD 360 C-6 has the high, removable hump. My '75 F100 2WD 360 C-6 has the low hump version. Pretty sure all 4 speed 2WD were high humps also.
Either way, if you have a low hump version and need a high hump, it simple to cut out the opening in the floor. The floor pan is stamped with the outline of the removable hump and where the fastener clips go, just be sure to cut about an inch inside the line or the hole will be too big.
Here's a picture of a high hump with the tunnel cover removed and one of the low hump.
Old Feb 9, 2017 | 07:51 PM
redcreekauto's Avatar
redcreekauto
My 74 F250 with 460 and a C6 2WD has a high hump, removable.
Old Feb 9, 2017 | 08:13 PM
Arbiter's Avatar
Arbiter
Thanks fellas, I think that clears things up nicely.
Old Feb 9, 2017 | 11:13 PM
77&79F250's Avatar
77&79F250
And if not....
79fordcummins
Feb 8, 2012 04:53 AM
cewofford
18
Aug 16, 2010 12:26 PM
cousinit77
Apr 20, 2010 11:17 AM
smokn03
1983 - 2012 Ranger & B-Series
Dec 12, 2007 08:45 AM
Mike W
Aug 25, 2003 07:37 PM
