Sponsored by: Auxito
Check Engine Light - Mass Airflow Sensor
Old Aug 28, 2003 | 08:59 PM
dmo00's Avatar
dmo00
Question Check Engine Light - Mass Airflow Sensor
Hello,
Could someone please help. My 2001 SuperCrew (5.4 & 4X4), only 500 miles after the warranty expired, had its Check Engine light turn on. I had it checked at AutoZone and a Mechanic and they both confirmed the only code to be a low voltage reading on the MAF/VAF Sensor.
The mechanic cleaned the sensor but it had no effect. Since his recommendation was to change the MAF Sensor, I ordered a Granatelli sensor and a K&N filter and put them on myself.
It did not work. I think the truck is peppier but the light is still on. I did leave the battery unhooked for a while to reset the system. The truck hesitates on depressing the accelerator but runs.
Any ideas PLEASE?
Thanks!
Old Aug 29, 2003 | 12:05 AM
Racerguy's Avatar
Racerguy
Hi dmo00 and welcome to FTE
Do you know what the code number was that was retrieved? It will be a P something. If you can post that it would be helpful.
Old Aug 29, 2003 | 05:21 PM
dmo00's Avatar
dmo00
P0102 - The same as before MAF/VAF Sensor Circuit Voltage Low
Old Aug 29, 2003 | 06:30 PM
AegisSailor's Avatar
AegisSailor
P0102 Possible Causes:
- MAF sensor disconnected
- MAF circuit open to PCM
- VPWR open to MAF sensor
- PWR GND open to MAF sensor
- MAF RTN circuit open to PCM
- MAF circuit shorted to GND
- Intake air leak (near MAF sensor)
- A closed throttle indication [throttle position (TP) sensor system]
- Damaged MAF sensor
- Damaged PCM
Old Aug 29, 2003 | 11:05 PM
dmo00's Avatar
dmo00
What do these acronyms stand for?
PCM, VPWR
I first noticed this when I had to depress the accelerator about 1" before the truck reacted (no smooth starts from a light). Could this point to the TPS? Where is it located if it does?
Thanks in advance - this is helping.
Old Aug 30, 2003 | 01:40 AM
AegisSailor
PCM is the Powertrain Control Module (your computer). VPWR is Vehicle Power
Old Aug 30, 2003 | 08:13 AM
Racerguy's Avatar
Racerguy
Near the top of this forum there is an "acronyms and definitions" post in case you're wondering what anything else is.
Old Sep 4, 2003 | 09:26 PM
dmo00's Avatar
dmo00
AegisSailor: I should have followed your line of thinking. I gave up and took the truck to another mechanic. After about an hour he found that the source of the problem was a family of mice creating a nest under the air filter box (never saw it) and they were using wiring to build the nest. The wire to the ECM was chewed off completely.
Thanks for the help anyway!
Old Sep 4, 2003 | 10:11 PM
AegisSailor
Can't take the credit, that was out of the manual. I'm glad you got it fixed though
Old Sep 4, 2003 | 11:58 PM
Racerguy's Avatar
Racerguy
Good manual you have there AegisSailor
Old Sep 5, 2003 | 07:41 AM
AegisSailor
Yeah, got it from some guy I met online
Old Sep 8, 2003 | 11:18 PM
Majestic99's Avatar
Majestic99
Where was the ECM Wire....
i eat hybrids
Modular V10 (6.8l)
Feb 25, 2018 05:23 PM
kpchambers
2009 - 2014 F150
Nov 12, 2015 03:44 AM
Tom Humbert
2009 - 2014 F150
Jun 30, 2015 06:50 PM
NoobMechanic
1997 - 2003 F150
Dec 13, 2013 06:46 PM
RADVRA
1997 - 2003 F150
Aug 14, 2003 11:16 AM
