Exhaust work info needed.
Hey everyone! I'm finally getting my exhaust manifolds fixed. I have a couple issues that I'd like a little bit of info or guidance on. The flange on the back of the headers, I was attempting to remove the bolt on it and it's so badly rusted the nut was eaten away and when I started turning it it rounded off completely and I wanted to know if there's any easy way to get that off. It's in a really tight area or I'd just cut it loose. My next and biggest question is catalytic converter related. Mine were at some point cut and gutted. I've been looking online for a complete system to use and replace them and the entire y pipe but can't find it. Does anyone know if I can find such a thing? I can find them for chevy trucks but not mine. Or would I be better off to finally get the old y off and have the ones on it cut and have new ones welded on and reinstall when I get the exhaust manifolds on?
1999 F250 7 Lug with the 5.4.
I'm pretty sure I've seen OEM stuff on Ebay...then there Tasco or Fordparts.com or RockAuto.com but if you find OEM it will be pricy !!
Many go with after market which you can get with less hassle and money if your careful. Magnaflow sells some replacement items. If you're interested in OEM as possible and not having CEL then you need the Catalytic Convertors that have O2 sensor bung already in them.
if you have what looks like 4 catalytic convertors many get by with 2 with no issues unless you are in a rea that has those annual inspection then you might not.
You might have some luck your local salvage yards getting the whole thing? It can get kinda dicy with buying used catalytic convertors out of a salvage yard, depending on you local laws.
Any suggestions on how to get the flange off my manifold?
Thanks for your input hopefully I can figure something out.
get several wheels. I Presume that the bolts are all rusted and deformed to where you can't take it apart?
If you think there is room for something larger then a 4-1/2 grinder with a cutoff wheel works well, or a sawsAll .
That's an understatement on this one haha. It's the one on the inside towards everything and I could barely reach it with my long extension. I guess I'm either gonna bite the bullet and get me a small cut off tool of some sorts or maybe see if the neighborhood loan program could help me out.
As I was trying to get them off it turned a little and then squeaked as it was turning and when I tried to get a better position on it I could feel it slip and round off. One of the moments you know you just screwed up.
Sounds like something to try anyways. I'll probably look for my replacements before I try it. I'll give it a few shots of penatrating fluid before and see if that will help as well.
Matt Js 54
28
08-19-2019 09:43 AM
