massive coolant leak.
Old Jun 4, 2007 | 12:55 AM
Tofudi's Avatar
Tofudi
When I turn my truck on coolant comes poring down. I can't find exactily where it's coming from. I assume water pump. I've read once in a book that there's a weep hole, or some thing somewhere but, I've never been able to find one to verify that rumor. I pressed the radiator hose and felt and heard a shoosh and bubbling noise. I've narrowed the leak from somewhere under water pump to above crank shaft. In that little area you can't see.
So, this means new water pump?
On top of that my girlfriend's Camaro's clutch has completely burnt out. Leaving me with no transportation and three projects over budjet.
Any leak/pump input? Thanks a lot, guys.
Old Jun 4, 2007 | 05:00 AM
RubberDuck's Avatar
RubberDuck
Yes, the water pump has a "weep" hole. It's really about the size of a #2 pencil. It's under the snout of the pump. What let's go to make it start pouring out of that hole, I couldn't tell you. But it does. Yeah, sounds like water pump city to me. I can't remember if you can run your hand under the snout with the pulley on or not, but if you can, do it. You'll feel the hole.......I said "feel the hole"
Old Jun 4, 2007 | 07:28 AM
tjbeggs's Avatar
tjbeggs
Sounds like a water pump to me too. It is very difficult to see the leak from top or bottom but thats where they leak.
