water pump leak?
Old Jan 2, 2001 | 12:07 PM
scotty's Avatar
scotty
water pump leak?
I think that my water pump is leaking. at first I thought it
was just a loose clamp, but then noticed that the fluid was
coming down the hose from up by the pump. I can't tell for
sure, but the leak seems to be coming from the bottom of the pump
itself. Is this a common occurrence? I can get a reman. pump for
$18, but I want to be sure that the leak is actually from the
pump. Can it be pressure tested somehow? (It never froze, by the way)
Scott
'67 F100
Old Jan 2, 2001 | 12:29 PM
StockMan's Avatar
StockMan
water pump leak?
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
It's often hard to tell for sure where a leak is coming from in that area, but assuming you carefully checked the hoses then I recommend you get the reman. pump, as this is likely a leaky pump, but only you can tell for sure. There is a small hole on the underside of the pump. When the seal goes, coolant spews out this hole. You may see the remnants of this leak when you remove the pump. $18 is pretty cheap insurance though anyway. Every have a water pump fail while on the interstate?
[/FONT]
[LINK:www.hometown.aol.com/tbeeee|http://members.aol.com/tbeeee/page/registrysig.gif]
Old Jan 2, 2001 | 03:31 PM
scotty's Avatar
scotty
water pump leak?
Thanks, it does appear that it's leaking from that little
hole on the underside of the pump. I'll take that $18 right
on over to NAPA.
Thanks again,
Scott
Old Jan 2, 2001 | 07:47 PM
66ranger's Avatar
66ranger
water pump leak?
new pump is worth it. My pump on my 300 6cyl looked like it was leaking, but slight seep from heater hose connection was all that it was. The old days of just repacking the water pump on the Model A are gone, maybe thats a good thing!
Old Jan 2, 2001 | 11:21 PM
390GT's Avatar
390GT
water pump leak?
xtmsports
Jan 12, 2010 08:28 PM
mtl93ranger
Jan 29, 2008 09:32 PM
Truckboy
Mar 14, 2006 12:59 PM
Scott's 88 F150
Mar 8, 2004 07:19 PM
ejmatthews
Aerostar
17
Aug 6, 2003 11:28 AM
