I'm considering where I could install an hidden switch, that the truck wouldn't start anymore.
Don't know which contacts of the ignition switch or any other line to interrupt. The switch should not affected to high amps. Is there need for a relays or does it do a simple line to disconnect with a switch?
Any living examples working easy and effective?
yes, I have been wondering about this for a while too,73-77 no interior hood lock and the latch is accessible from the outside. You don't even need a key to drive it as there is no locking steering or gear shifter.Correct me if I am wrong but all you need to drive it off is a remote starter and a jumper wire and it's gone that quick.
I would kill switch the negative side of the coil or use a module kill switch. Then a power jumper to the coil + isn't going to work either.
Slightly different way of getting there but my truck has an electric fuel pump. I hid the on/off switch up under the dash. I can reach it and turn it off. It might start but they're only going to get a block or so before the carb runs out of gas. Later, Shortbox4x4
Put a battery disconnect switch in the negative battery cable.....you could hide it in the core support, put it in the firewall so it is accessible from inside the truck or mount it under the front bumper.......also handy when you are working on the truck to effectively disconnect the battey.......Caterpillar even sells a style that uses a key.......
I have a kill switch to ground the - side of the coil. For those that already have a tach installed, it becomes an even simpler installation to ground the tach lead wire through a hidden switch.
":I would kill switch the negative side of the coil or use a module kill switch."
This seems relatively simple right? Just run the negative coil wire into the cab with a hidden switch? Then the other side of the switch back to the coil?
i have always used a old school brake line lock,its like a emergency brake,i hide it under the dash or under hood,you have to run brake line to it,just pull handle down and the brakes are on.
Can hack into the wire harness under the dash. The ignition coil + Positive feed's resistor wire is in it which runs from near the fuse panel to about middle of dash. Maybe add a 30Amp fuse inline as well for safety.
Would need to have good wiring diagrams to sort out which wire.
edit: Complicate it where Nobody wants to touch it! stuff in EFI, and add piles of unused wires just to confuse everyone!
A buddy of mine installed a lock like this in the floor of his Z-car, under the floor mat. Ran the negative lead of the coil (I think it was) through it.
