Module, module, who's got the module?
Old Feb 5, 2017 | 06:19 PM
forkliftjoe's Avatar
forkliftjoe
1995 F150 4.9 - Too much confusion over which module fits my truck. Oh Really's has the DY1075 Motorcraft listed, but I try that thru Amazon and they say it doesn't fit my truck.
- Ford Parts online sez it uses a DY533. Don't get me started on the aftermarket guys like Standard or NAPA....
Mine is fender mounted in the heat sink.
Old Feb 5, 2017 | 06:24 PM
forkliftjoe
Photo of Module
Last edited by forkliftjoe; Feb 5, 2017 at 06:39 PM. Reason: Smaller File on Photo
Old Feb 5, 2017 | 08:41 PM
forkliftjoe
AND, oReally's and NAPA call for the same part number regardless if it's a Inline 6 or a V8! What gives?
Ford online sez they're 2 different part numbers.
Old Feb 6, 2017 | 01:32 AM
arse_sidewards's Avatar
arse_sidewards
The ignition module doesn't care how many cylinders you have, it just powers the coil based on the signal it's getting from the distributor (which varies based on cyl count). It doesn't know the difference between 4cyl at 3000rpm, 6cyl at 2000rpm or a v8 at 1500rpm.
Old Feb 6, 2017 | 06:31 AM
timbersteel's Avatar
timbersteel
Maybe this will help.
https://www.ford-trucks.com/forums/1...black-icm.html
Old Feb 7, 2017 | 12:04 AM
forkliftjoe
Not having much luck finding a genuine Motorcraft Module.
Standard Ignition has 2 different black ones, an LX241 and an LX241T...
What's the "T" stand for? Anybody know?
Old Feb 7, 2017 | 01:09 AM
timbersteel
The "T" refers to the "Economy" brand, cheaper.
Search on Amazon for the correct Black "Fender Mounted" ICM.
NOTE: I just searched on RockAuto, using the "Part Number" for "Motorcraft DY1077. It's $57.79
It's available, though not listed in the correct subcategories for Ford trucks for 1995-1997.
Old Feb 7, 2017 | 03:09 AM
forkliftjoe
And that DY1077 will work on my 4.9?
Old Feb 7, 2017 | 04:23 AM
timbersteel
Yes.
As was stated earlier, the ICM doesn't care what size engine is in the truck. The PCM is what determines what ICM is needed.
Old Feb 13, 2017 | 03:52 AM
forkliftjoe
We need to start our own part numbers library....
Old Feb 13, 2017 | 04:22 AM
forkliftjoe
Traced my problem to a set of bad spark plugs...
I am assuming somebody dropped the box of spark plugs before I got them and a couple of them have hairline cracks (I can't prove this, but I JUST put them in)
I replaced all six again and the problem cleared up.
randre
Dec 29, 2023 11:57 PM
dvldog458
Jan 9, 2004 12:26 AM
NJbronco138
1978 - 1996 Big Bronco
May 11, 2003 10:34 AM
homedepothauler
Nov 12, 2002 09:21 AM
GammaDriver
Jul 8, 2002 08:51 PM
