Sponsored by: Auxito
Key less entry problem
Old Feb 4, 2017 | 11:58 PM
sparkyben1's Avatar
sparkyben1
4wd Low
Hi all, my 2002 F150 Super crew 4.6L, 4 door, 2*4 is messing with me. Lol. I had to replace the ignition actuator rod, and when everything was back together, the keyless remote didn't work. I tried multiple times to relearn the fob. I went through the process and got all the right sounds, lock cycle after 8, lock cycle after fob button, and lock cycle after turning off the ignition switch, and blah, blah, the remote still doesn't work. Any ideas? Is it more likely to be the fob, or the module, and then which module would be correct? Thanks sparkyben1.
bcaughhorn
May 14, 2016 09:19 AM
vetazac
Mar 24, 2010 06:38 PM
Meile's PS
Mar 17, 2006 06:00 PM
Mohawk Man
1983 - 2012 Ranger & B-Series
Aug 21, 2003 07:39 PM
firemedic33
1997 - 2003 F150
Jun 14, 2003 09:39 PM
