IMPORTANT- ALL TRANSMITTERS(FOBS) MUST BE PROGRAMMED AT THE SAME TIME!!!!
1. TURN KEY SWITCH FROM OFF TO RUN 8 TIMES WITHIN 10 SECONDS, ENDING IN THE RUN POSITION. IF THE MODULE HAS ENTERED PROGRAM MODE, IT WILL LOCK THEN UNLOCK ALL DOORS.
2. WITHIN 20 SECONDS, PRESS ANY BUTTON ON A FOB, THE DOORS SHOULD LOCK THEN UNLOCK TO CONFIRM FOB IS PROGRAMMED. REPEAT THIS STEP FOR REMAINING FOBS.
3. IF THE DOOR LOCKS DO NOT RESPOND FOR ANY FOB, WAIT SEVERAL SECONDS AND PRESS A BUTTON AGAIN.
4. TURN THE IGNITION SWITCH OFF, OR WAIT UP TO 20 SECONDS AFTER STEP 2, TO EXIT PROGRAM MODE. IF A FOB HAS BEEN PROGRAMMED (OR REPROGRAMMED), THE MODULE WILL LOCK AND UNLOCK ALL DOORS ONE LAST TIME TO CONFIRM.
I tried to program the fob according to your instructions but it would not work. The system that is installed in my truck is called Auto mate. Is this a Ford security system? The fobs that I got when I bought the truck have Ford on them and they work. Thanks for the instructions.
