Rke module
Old May 13, 2016 | 07:57 PM
bcaughhorn's Avatar
bcaughhorn
Rke module
I can cycle my key 5 times and the doors lock and unlock but the fob doesn't work. I have tried multiple known working fobs and still nothing.
Where is the rke module located?
Not behind the ash tray or right side of the steering column
Old May 14, 2016 | 08:48 AM
Pirsch Fire Wagon's Avatar
Pirsch Fire Wagon
The RKE is part of the GEM and is not independently serviceable.
If you have already done the following verbatim - seek a GEM Repair or Replacement GEM. (There are also aftermarket Kits).
1. Turn the ignition from OFF to RUN five times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
2. Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
3. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
4. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
Old May 14, 2016 | 09:19 AM
bcaughhorn's Avatar
bcaughhorn
Looks like I'll be getting that alarm with remote start sooner than later!
davidkstyler
Feb 3, 2023 11:48 AM
Aussie Jones
Nov 6, 2008 12:02 AM
christoph
Oct 7, 2007 02:14 PM
97f150sk
Electrical Systems/Wiring
Apr 20, 2004 07:26 PM
JB7
1978 - 1996 Big Bronco
22
Dec 3, 2003 09:58 PM
