Attaching a tool box
Old Feb 3, 2017 | 02:23 PM
Raven17's Avatar
Raven17
I tried to search. No help. Trying to mount an in bed toolbox that came out of 2009. What kind of screws is everyone using and where to get them. I know the wrong kind will cause corrosion of the bed. Thanks for the help.
Old Feb 3, 2017 | 02:36 PM
bikerman5345's Avatar
bikerman5345
If you can use bolts you can drill your hole and then seal the bare surface covering the aluminum, you have to prevent metal on metal contact from dissimilar metals. And then you can use a cad plated bolt or other type of fastner. You can always order aviation grade hardware. We use this stuff on airplanes and unless exposed to some type of electrical current or other type of catalyst your pretty safe from corrosion. And by catalyst i mean certain types of cleaners and degreasers will wreck havac on aluminum.
Old Feb 3, 2017 | 04:53 PM
petei's Avatar
petei
I have the same problem the old tool box don't fit is too wide for the bed.So I raise 3 in the box on 3x3 aluminum square tubing and then I make a SS bracket to bolt on the existing tie down in the back of the box.I don't drill no holes into the bed and the tool box is not moving at all.
Old Feb 4, 2017 | 12:55 PM
black08's Avatar
black08
My fuel tank / toolbox combo was 1.5" to wide for the new truck. I had it notched on the back corners so it would still sit flat on the floor. I am now going to use the new box link pockets to secure the tank as opposed to bolting it down.
Old Feb 4, 2017 | 01:03 PM
black08's Avatar
black08
Old Feb 4, 2017 | 01:46 PM
Uzumati's Avatar
Uzumati
Couldn't you just use some Aluminum bolts to prevent the galvanic reaction or would they have to be bolts with the same alloy percentages?
Old Feb 4, 2017 | 01:54 PM
TomD1's Avatar
TomD1
You can use steel bolts, just remember to use Zinc chromate primer.
Old Feb 4, 2017 | 03:20 PM
rustyshakelford's Avatar
rustyshakelford
This is what I used. Going to get a second set just because of how I have it mounted. One set should be good for 99% of people. Holds good from my experience
brett
http://www.northerntool.com/shop/too...?hotline=false
Old Feb 5, 2017 | 12:39 AM
spook222's Avatar
spook222
I just went to the local bolt store and got zinc plated hardware
Old Feb 5, 2017 | 09:57 AM
FOUNTAIN 1's Avatar
FOUNTAIN 1
put a bead of 100 percent silicone under edge no drilling needed . do it to all my trucks ; wont go anywhere
Old Feb 5, 2017 | 11:01 AM
mhoefer's Avatar
mhoefer
Interesting Fountain, I am watching this thread. I have a sweet custom made under cover tool box I am waiting to install. Thinking hardware of some sort to the lockable brackets. For good measure might also do your sopilicone bread, but would have to wait two more months so it can cure properly. I I'll have to dig the toolbox out of the tool shed and see how she fits first......
Old Feb 5, 2017 | 12:57 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
yup a little cold for silicone if no heated areas are available .. silicone fully cured is strong stuff .use it all the time .. had to use prybar to break seal when swiched mine from denali to the ford ..
Old Feb 5, 2017 | 06:07 PM
bikerman5345
Silicone would work. When I was younger I installed granite into homes and that's how those tops are secured with beads of silicone. Once dry it holds great. Also you can use j hooks to hook under the lip of the rails. That's how I installed mine. No drilling and no damage to the truck.
Old Feb 6, 2017 | 12:02 AM
RJC2's Avatar
RJC2
Mhoefer,
What is sopilicone bread?
Sorry, I couldn't help myself.
Old Feb 6, 2017 | 01:04 AM
FONRDAY's Avatar
FONRDAY
Yes I have done that
Silicone is great , I just used a bed cover this time instead. Now I have a great big tool box lol
Since my tool box is to wide anyways
edzakory
54
May 7, 2018 01:43 PM
adbscu
Jan 19, 2017 12:36 AM
Bently_Coop
Jan 4, 2017 07:33 AM
rts9364
2004 - 2008 F150
Apr 11, 2012 01:43 PM
koziol41
Aftermarket Products
Oct 10, 2006 06:41 PM
