Brakes problem after tune up...
Old Feb 3, 2017 | 01:53 PM
Stanislaw's Avatar
Stanislaw
Hi Guys,
So I did a complete brake job today on the front.
New disks and pads, and new hub on the front left as well.
This is not the first time I'm doing this, but still, have unexpected problem.
The job went well. I had no problems. Opened the reservoir cap when pressing the small pistons in (and checked the fluid level after the job)...
First of all - the car is braking as expected. Slow, fast, No problems, no wrong symptoms...no pulling to the side, no wrong sounds... Also no error codes on the computer...
But
I have the RED brake lamp on the dash - still light no flashing. Have no idea why ?? It is like no fluid warning, but fluid is there...
Second problem - when I'm slowing down, so pressing brake pedal gently, the stop lamps are going on, and after few seconds off (while pedal is still gently pressed). The still light from the stop lights required to break hard, with substantial force to the pedal...
Previously (before I did the job), the stop lights were on constantly, as long as I was pressing the pedal (no matter how hard)...
Got any ideas ?
Old Feb 3, 2017 | 03:07 PM
lincolnshibuya's Avatar
lincolnshibuya
your scanner can't read the codes properly, if it's lit then there's a code.
try going to a parts store and try it with their scanner (some of them have the latest that can read modules other than the engine.. trans & abs)
https://www.facebook.com/diyLincolnNavigator/
Old Feb 3, 2017 | 03:27 PM
Stanislaw's Avatar
Stanislaw
I use Forscan and can read abs, trans, airbag, comfort, pats and such...
The code for brakes is simply not there...
edit: I took it to the ford shop to have it scanned... They checked it with their scan computer - no codes as well..
davestro2000
1983 - 2012 Ranger & B-Series
May 24, 2019 10:48 PM
dunnc1989
Jun 11, 2012 08:03 PM
plessasrdjr
May 10, 2011 07:40 AM
green 69
Mar 10, 2010 12:03 AM
Bill4Kath
Escape & Escape Hybrid
Jul 26, 2005 11:22 PM
