bleeding brake master?
Old Feb 3, 2017 | 10:35 AM
good to doo's Avatar
good to doo
So I changed the brake line from the master to the PValve, so the master was completely empty when I did this(rear brakes line) not the front portion of the master it was still full. So we tried bleeding the rear brakes but no fluid is getting back there. Do I need to bench bleed this thing? If so is there a good way to do it on the truck? Or should I just pull it off?
Old Feb 3, 2017 | 10:43 AM
F250_Super_4X4's Avatar
F250_Super_4X4
1. Disconnect the brake lines at the master cylinder
2. Install flexible brake lines or prefabed brake lines that curl up and back into the reservoir
3. Fill reservoir with brake fluid so that the end of the lines are submerged
4. Have a friend pump brake pedal while you watch air bubbles being deposited into reservoir
5. When bubbles no longer appear, have assistant stop pumping brakes.
6. Disconnect flex/fabbed tubes and ensure no air enters system
7. reinstall brake lines and bleed lines
Hope that helps
Old Feb 3, 2017 | 10:50 AM
good to doo
Thank you.
Old Feb 3, 2017 | 10:56 AM
good to doo
Oh 1 more thing. Should we be pushing the pedal to the floor, when doing the master? I know how to do the rest after that.
Old Feb 3, 2017 | 02:20 PM
ultraranger's Avatar
ultraranger
The MC reservoir closest to the firewall is the reservoir for the front brakes.
The reservoir closest to the radiator is the reservoir for the rear brakes.
Old Feb 3, 2017 | 02:41 PM
good to doo
I understand that. JUst wondering how to bench bleed without removing the master. Also if I bench bleed on the truck do I put the pedal all the way to the floor like we do when bleeding the brakes. Thanks.
Old Feb 3, 2017 | 03:30 PM
F250_Super_4X4
Yes, give it all shes got, you want to squeeze every bit of air out of the MC plunger. Also remember that when bleeding the brake lines you have to bypass, I use small vice grips to pull the plunger, the proportioning valve. Ford makes a clip but I have yet to own one.
Old Oct 15, 2022 | 03:19 PM
tbm3fan's Avatar
tbm3fan
I have been driving the truck a bit now and really like the braking action I have vs. the old action. Old was lots of muscle work with the right leg and that is now gone. It is more like a power disc brake feel even though it is all drums and of course needs more distance to stop with the drums. So naturally I am not liking when a red light changes right at that critical moment when you can't quite go through the yellow and so you have to hit your brakes. So when that happens, like twice last night, the voice inside my head says "come on baby you can do it." Although I was tempted since with the now 390 and 3,25 gears the truck has a lot of punch when you step on it. Moves fast, stops slow, a great combination.
I used it last night to pick up my son from what would be considered his first school dance in 8th grade. At Alamo all cars will be Teslas, Escalades, Yukons, and so forth. I pull into the line with the low rumble from my truck to get my son and the kids around him point and start to ask him. Yeah, this is a "truck" and all the rest of you are imposters.
wilcam47
Mar 9, 2013 09:58 PM
Stephen67
20
Jun 23, 2010 04:55 PM
951500
Nov 5, 2008 07:09 AM
nightshifter
Aerostar
Oct 9, 2004 11:10 PM
chmuraman
Mar 11, 2004 06:06 PM
