Mag Style Lug Nuts
Mag Style Lug Nuts
Mounting my Western Turbine wheels on my 72'. Never mounted wheels with mag style lug nuts before. What a pain. How many ft lbs to tighten mag style lug nuts? Can't get them to quit giving at 90 ft lbs. Just keep giving. Torque wrench won't even click. Wheel flange is 1 inch thick. All the lug nuts I could find locally have a 3/4 inch shank. Don't know if that makes a difference
Yes they do have washers. I think that was part of the problem. The washers were compressing to the shape of the lug nut. Once they took shape they torqued down. But, I also think I was over torquing them. What I've read gives me the impression 90 ft lbs may be a bit much for this style of lug nuts.
MAYBE? Dorman has some good stuff unavailable from anyone else and some not so good. I have found in the past with the coned seat type lug nut I thought they where a little soft. I would go with nuts from a wheel supplier or somebody like Summit Auto and look for major brand stuff. You could also look at replacing the studs with a 9/16 replacement, they ar a lot stronger.
Fordenthusiasts
21
05-14-2009 04:31 PM
