Swapped compressor wheel.
Old Feb 1, 2017 | 07:47 PM
Slyhuntr's Avatar
Slyhuntr
Decided to try a new wheel to see if I can stop the surge during hill climbing with our 5er. Old wheel looked great with no dusting or nicks. New wheel sure has a whirl when it spools up, but sounds cool. Haven't pulled trailer since swap yet. Truck still only has 85k on the clock.
Old Feb 1, 2017 | 09:36 PM
z31freakify's Avatar
z31freakify
That wheel will stop the surge, but I would of opted for a billet one, they do indeed lower gets and give a bit more boost.
Old Feb 1, 2017 | 09:58 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
He meant to say EGT's and not gets, probably auto-correct trying to run his life...
Old Feb 1, 2017 | 10:01 PM
guitarpicr's Avatar
guitarpicr
Is the new one a stock wheel - Kinda look the same
Old Feb 1, 2017 | 10:13 PM
Slyhuntr's Avatar
Slyhuntr
What I read is it is a stock for an older model. It has short blades every other blade, one extra blade.
Old Feb 1, 2017 | 10:19 PM
Sous's Avatar
Sous
FTE Emeritus
I am in agreement with Adam here that if you are not emotionally attached to the new wheel, send it back and purchase a RiffRaff 4/4 or SPTurboost SPX billet wheel.
They will also cure any surge problems, look good and perform much better.
Old Feb 1, 2017 | 10:27 PM
Slyhuntr's Avatar
Slyhuntr
Funds are a bit tight right now, eventually I plan to do several upgrades and when I do a billet wheel will be on the list.
Old Feb 1, 2017 | 10:30 PM
z31freakify
That's right Sous, dam auto correct lol...
thx997303
May 4, 2019 06:29 AM
diehardstroker
59
Apr 10, 2017 05:48 PM
Chris56ford
May 10, 2014 03:04 PM
Jamie Arceneaux
Sep 4, 2013 09:53 PM
jroy
34
Feb 8, 2008 08:15 PM
