Fixed auto locking hubs
Old Feb 1, 2017 | 01:10 PM
Njstern87's Avatar
Njstern87
Just wanted to take a moment to thanks everyone on here. My auto-locking hub system gave up the ghost during chain controls in Donner pass. Was able to manually lock them in and get home safe.
After I read the countless threads on here I found the vacuum solenoid wasn't working. Swapped that out to find a vacuum leak, fixed the leak and got the esof working again. Than had the pax side hub freeze up in lock, so again a visit to FTE. Found the write up on guzzles website, did the disassembly, clean, lube and reassemble and now the whole thing is working as intended.
Thanks again. Love what an amazing resource this site is.
Old Feb 1, 2017 | 07:06 PM
AllaboutMPG's Avatar
AllaboutMPG
Congrats on getting her working right.
You should consider becoming a member. Get some FTE bling, get rid of the pop up ads, and it's cheaper than an Alldata subscription and more helpful.
I love this site
Old Feb 1, 2017 | 07:34 PM
erikkloss's Avatar
erikkloss
Just curious, did you use an aftermarket solenoid or oem?
Old Feb 1, 2017 | 07:51 PM
Njstern87's Avatar
Njstern87
I have been considering it...just not in the budget currently..someday i hope to though
And I used an OEM one..I have never had much luck with aftermarket sensors and such lasting very long.
Old Feb 1, 2017 | 08:06 PM
erikkloss's Avatar
erikkloss
Thank you for letting me know. I had a problem with my esof not unlocking with new solenoid. It turned out to be bad aftermarket solenoids. OEM fixed it.
Old Feb 2, 2017 | 09:00 AM
BillyBob69's Avatar
BillyBob69
I just went through the entire ESOF system as I have been manually locking my hubs for the past 5yrs. Decided to go through it all while replacing ball joints. It is nice to have them working again.
New vaccuum zerks, cleaned the passages etc. And all because of the info from this forum.
Old Feb 2, 2017 | 12:02 PM
andym's Avatar
andym
I'm in the middle of doing the same on my truck as well. I have it all torn down and cleaned up, ready to put back together with new parts as soon as I can afford them. I just put together a parts list for all the work I'm doing (some engine mods too) and it sits at about $2500 right now so it might be a little while before it's back on the road.
I've done countless repairs on all my trucks that I couldn't have done without FTE. This site has literally saved me thousands and thousands of dollars.
SOB Racing
Sep 12, 2012 03:13 PM
wallz
Jan 19, 2011 11:01 PM
Immortal_Ben
Mar 9, 2009 07:58 PM
hdman6
Sep 19, 2008 08:41 PM
grcutter
Nov 11, 2003 09:03 PM
