Need Carb help.
Old Feb 5, 2017 | 08:22 AM
SemperMonster's Avatar
SemperMonster
Oh great, doesn't look too hard at all. This is how she currently looks. Not bad for 700$
Old Feb 5, 2017 | 08:56 AM
FuzzFace2's Avatar
FuzzFace2
Thank you Lightning on the bowl vent hose & lever, thought it may have been just mine.
For my choke I am on the fence on how I am going to do mine.
Stock uses 7 volts off the ALT, yes 7 volts not 12 volts. It also uses hot (clean) air pulled from the air filter thru a metal tube that runs thru the exh. manifold to heat it up then up to the choke housing. The 2 work together to open the choke. You can run into issues is you only run 1 or the other.
I may go stock but I plan on a 3G ALT and have to look into picking up 7 volt power.
I am also running EFI exh. manifolds and they do not have the pass thru of the metal tube for hot air. The work around is get copper tubing and wrap it around the manifold to heat the air. Then it would work like the stock set up, just does not look too good in my book.
Another way is to replace the black 7 volt cap on the choke with a 12 volt one, plug the air tube hook up at the carb as you will have a vacuum leak, run 12 volts with motor running (relay) to the new cap and be done.
This is the way I am leaning to go.
Dave ----
Old Feb 5, 2017 | 02:21 PM
Gary Lewis's Avatar
Gary Lewis
Dave - According to what I've read, such as this, the 3G does have a stator terminal where you can get 7 volts to power your choke's heater. Should be easier than rigging up a relay, but either way works.
On the exhaust, it doesn't look like the 4.9L got EFI until '87, so I didn't put that illustration on my web site. But, you can see it on Page 20 of Section 52.2 in the Illustrations.
Old Feb 5, 2017 | 07:10 PM
FuzzFace2's Avatar
FuzzFace2
Thanks Gary, I remembered you guys posting about the 7 volts from the 3G ALT.
Thing is I would also need to wrap copper tubing around the EFI manifold up to the choke also as the 2 work together to open the choke. I just don't like the copper wrap as it will look hooky.
That is why I want to go with a 12 volt black cap and so it will only get power when running a relay will be used to power the cap.
Thanks for the exh page, will have to give it a look over.
Dave ----
Old Feb 5, 2017 | 07:54 PM
Franklin2's Avatar
Franklin2
The best way to run a 12v choke is to run it through a oil pressure switch. If you hook it to key on power, and for some reason you have a little trouble starting the engine, all that time you are messing with the engine with the key on cranking it over, the choke is getting power and is starting to open up, but the engine is dead cold and hasn't run. This can aggravate your starting problem.
can0fspam
Jul 30, 2018 11:23 PM
jazzmaffy
Jun 18, 2010 11:24 PM
royboytrip
Nov 14, 2009 07:10 PM
royboytrip
Nov 3, 2009 07:22 AM
wmdhill
Dec 23, 2006 11:02 AM
