Replacing brake lines
Old Jan 31, 2017 | 08:21 AM
kyle j's Avatar
kyle j
Replacing all lines from master cilinder and the one that runs along the oil pan. Might be a dumb question but Do I just need to bleed front calipers after i pull off old lines and put new ones on? Will there be air in the master cilinder? First time replacing these lines any advice helpful thanks. Kyle
Old Jan 31, 2017 | 09:18 AM
farmert's Avatar
farmert
As long as you keep the master cylinder topped off, you don't need to bleed the master. After the lines are replaced, bleed the calipers in the normal way, checking to see that the master cylinder fluid never drops enough to introduce air into the lines, which shouldn't be a problem if the reservoir is full when starting the bleeding process.
Old Jan 31, 2017 | 09:20 AM
kyle j's Avatar
kyle j
Thanks seems easy enough
Old Jan 31, 2017 | 10:34 AM
knottyrope's Avatar
knottyrope
I like to cap the lines so it don't drip while working on it
running Stainless lines?
Old Jan 31, 2017 | 10:39 AM
kyle j's Avatar
kyle j
Yup found a complete set of pre bent stainless so I was gonna do all the front end lines. What do you mean by caping them? I was just gonna remove them then thread in new ones one by one?
Old Jan 31, 2017 | 11:05 AM
knottyrope's Avatar
knottyrope
last time I did lines, it took me a while to get the old ones out and the MC dripped fluid
I used a fuel line with bolt and clamp to stop it from dripping.
nice find on pre bent set
Old Jan 31, 2017 | 04:32 PM
madpogue's Avatar
madpogue
Where did you find pre-bent stainless?
Old Feb 1, 2017 | 10:49 AM
mcali2's Avatar
mcali2
E bay has them. I ordered a complete set for my truck. worked great.
Old Feb 1, 2017 | 10:51 AM
kyle j's Avatar
kyle j
https://sstubes.com/
Old Feb 1, 2017 | 10:59 AM
knottyrope's Avatar
knottyrope
their prices seem ok too, let us know how well they install
Old Feb 1, 2017 | 11:02 AM
kyle j's Avatar
kyle j
Will do gonna throw in ps lines and brake lines this weekend hopefully I'll let you guys know how it goes
dmccorkle911
18
Aug 3, 2014 03:24 PM
MattyJessome
Sep 28, 2010 05:49 PM
blakeusa
Jan 23, 2008 02:32 PM
78 Ranger
May 20, 2007 12:38 PM
god.boots
Apr 3, 2006 03:20 PM
