master cylinder brake lines
Old Jan 23, 2008 | 01:59 PM
blakeusa's Avatar
blakeusa
Any recommendations on new hard brake lines- ie. bend myself or get pre bent from a vendor. Just want the set for the master.
Just put in new front end and brakes and when bleeding figured my master was leaking too...... will replace the master, but brake lines are rusted at fittings.
Do I need the circles, or can I just bend and go to P valve?
Thanks
Old Jan 23, 2008 | 02:32 PM
psquare7575's Avatar
psquare7575
The circles are there to prevent lines cracking from engine/road vibrations... flexing between the body and the frame where the prop valve is mounted could theoretically cause this.
