Sponsored by: Auxito
Check engine light Vaccum lines
Old Jan 30, 2017 | 10:50 PM
jonAknight's Avatar
jonAknight
I got a question, what is after ac hose vaccum left side on a 10 th gen 4.2l engine bay by the firewall, to the right of the blue thing, right of that on that line their is a 2 end diameter rubber vaccum line? What is that called, i need a replacement.
And I cant find one from Napa.
Please help.
Old Jan 31, 2017 | 01:02 AM
Bluegrass 7's Avatar
Bluegrass 7
Righttttttttttttttttttttttttttt.
How many do ya want?
Stop the nonsense and Id the part if you want help.
Start with the year at least.
Post a photo.
Ya got an I-pad don't ya?
Good luck.
Old Jan 31, 2017 | 07:39 AM
enriched&beyound's Avatar
enriched&beyound
Yeah..uuumm, as hard as you were trying to describe the part its pretty hard to understand what your trying to pinpoint. Pictures do help.
If you can not post a picture...maybe use google images and copy and paste something that shows your item ...or ford parts Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com
Look up your truck, find the part in question and that should get you a part number and what to call it.
Old Feb 1, 2017 | 06:32 PM
jonAknight's Avatar
jonAknight
Uuuummmmm ok,
Old Feb 1, 2017 | 10:33 PM
Bluegrass 7
Your photo shows a vacuum TEE on the left connected to a black line on the right with a short section of hose.
What hard about that? Forget any part number.
Get a piece of vacuum hose the right inside diameter that will slide on both ends, seal, and replace it.
Good luck.
Old Feb 2, 2017 | 12:48 AM
Sam I Am's Avatar
Sam I Am
And you are going to want to inspect the rest of your vacuum lines. As bad as that one looks, the rest are just as bad unless already replaced.
Old Feb 3, 2017 | 07:18 PM
jonAknight's Avatar
jonAknight
What is the ford part number?
Old Feb 3, 2017 | 07:27 PM
Bluegrass 7
Go to a dealer parts dept. and ask.
Good luck.
PEG
1997 - 2003 F150
May 28, 2019 10:29 AM
IllinoisJon
2004 - 2008 F150
Dec 8, 2016 09:25 PM
benbuilder
Aug 11, 2016 05:44 PM
JonathanN
Mar 31, 2011 10:44 PM
94_9high_250
Nov 19, 2005 09:42 AM
