new radiator fit
Jan 30, 2017 | 01:45 PM
new radiator fit
looking for new radiator for my 1971 f250 300 6 cylinder, the radiators i have been looking at have engine side flange, that won't attach to my radiator support, seems like the flange should be away from engine, help
thanks
dave
Jan 30, 2017 | 01:51 PM
The one I recommended from 1-800-radiator has both mount flanges. It will mount either on the raised mounts or straight to the radiator support.
Jan 30, 2017 | 02:01 PM
did my truck at one time have raised mounts?
Jan 30, 2017 | 05:13 PM
There were two different mounting styles, but I don't know what dictated what mount it got.
Jan 30, 2017 | 05:28 PM
1 800 radiator you are talking about, is that the one in west michigan? i definitely need away from engine flange, looks like 4 holes for mounting
Jan 30, 2017 | 07:18 PM
If you call them their system puts you through to the closest location. I generally get radiators from Boise.
Jan 30, 2017 | 10:02 PM
Front mount & rear mounting the radiator, Front mount is like a 70 and the rear is a 75 up
Orich
Jan 31, 2017 | 06:59 AM
are we looking at the rear side of both of those radiator brackets?
Jan 31, 2017 | 08:51 AM
Quote:
Originally Posted by
vidaliaman
Yes Sir,
They both face the engine bay the way their sitting, the lower one mounts the rear mounting Rad.
Also all the 4wd trucks, I've seen use the rear mounting Rad support.
But many trucks that have 2wd also use either one of them that, I've come across.
So it's like you'll never know what's under the hoods until you look.
Orich
Jan 31, 2017 | 09:20 AM
lol, that is the truth! thanks
Nov 29, 2019 | 05:00 PM
orich
Yes Sir,
Orich
thank you for the photo. I was trying to figure this out. Wouldn’t you know it that the rear mount cost more.
Nov 29, 2019 | 10:10 PM
greg sutphin
1967/72 F100/350:
TWO different radiator supports. The one used with the Super Cooling radiator has a larger opening radius.
Super cooling radiator measures approx. 26 1/4" x 24 11/16."
Standard/xtra cooling and A/C radiators measure approx. 26 1/4" x 19 3/4."
And because there are TWO different radiator supports, there are TWO different fan shrouds.
newguy399
Oct 25, 2017 10:44 AM
Wayne64SS
Aug 27, 2013 01:40 PM
mrblonde108
Nov 29, 2011 05:03 PM
55forder
25
Mar 17, 2005 11:46 AM
