Driveway front end alignment
Old Nov 26, 2017 | 10:20 AM
Eric Fullerton's Avatar
Eric Fullerton
I've always just taken a heavy string and made a loop around all 4 tires. Even if the rears are narrower or wider, (narrow you can shim out) it gives you a perspective on the toe in / out. A line level wouldn't be out of the question, assuming the truck is sitting relatively level.
Old Nov 28, 2017 | 09:47 AM
Freightrain's Avatar
Freightrain
Originally Posted by tjc transport
i tend to not use a "level across the wood" deal because i rarely am on level ground.
I only used the level because it was long, straight edge. Not for leveling anything. Just to clarify the reason I used it.
Old Nov 28, 2017 | 01:37 PM
jas88's Avatar
jas88
Harbor Freight makes a tool that makes it easier to do it yourself, but it measures toe in degrees instead of inches. 2-4 deg in is good for our trucks.
BillyBob69
13
Nov 17, 2018 03:36 PM
aqnhfd
Feb 20, 2018 06:40 PM
86F150302
Jun 23, 2010 07:25 PM
totin_tools
Aug 14, 2007 10:47 AM
FireTail-AR
Apr 23, 2007 07:33 AM
