Sponsored by: Auxito
proportioning valves
Old Jan 30, 2017 | 05:56 AM
ssme2's Avatar
ssme2
Where is the proportioning valve located on these F 150 trucks now? if you swap rear drum to disc what vale is needed if necessary? Years ago P.V. were only on cars that had front disc rear drums. Drum / drum had none so if you have disc / disc is one necessary? Its not the master cylinder as it doesnt specify when buying one, thanks
Old Jan 31, 2017 | 06:19 PM
Bluegrass 7's Avatar
Bluegrass 7
It depend on the year and how the truck is equipped with a brake control systems.
Look along the frame rail for block where the line goes.
The rear most always uses a bit less pressure then the front so it does not brake traction before the front and utilizes auto brake system properly.
When the auto brake control does cut in, the ratio still has to be the same overall.
Engineering this brake pressure ratio depends on a lot of factors to maximize braking, minimize excessive pad wear on the front, the weight of the truck on each end etc.
Good luck.
Old Feb 6, 2017 | 05:27 AM
ssme2's Avatar
ssme2
Found out P.V. built into master cylinder on these trucks 97-03
Old Feb 6, 2017 | 11:45 AM
Rat/Ray's Avatar
Rat/Ray
Hello Everyone
1st timer here, and I am in need of advise with my 1967 F-100 drum brake system. It will not bleed out. No matter what I have tried the brakes paddle still goes down to the floor. I installed new wheel cylinders, rear lines, front brake hoses, new master cylinder with brake booster. Someone told me it the brake proportioning valve. But from what I have read that this rear truck did not have one.
Can someone please help me out.
Thanks Ray
Last edited by Rat/Ray; Feb 6, 2017 at 12:23 PM. Reason: Forgot to put in year of truck
Old Apr 18, 2020 | 06:48 AM
Board4RD's Avatar
Board4RD
Have you checked the piston size of the new MC compared to the OEM? My F3 has a 1 1/8" bore MC. Most dual chamber MC's that I found are 1". That smaller piston will put out less fluid and may not be enough for your OEM wheel cylinders. Worth looking into.
1972RedNeck
Jun 18, 2012 10:05 PM
RC-Doktor
Apr 24, 2011 12:23 PM
mt54
15
Nov 5, 2008 08:03 AM
hammerdn
Feb 24, 2003 12:19 AM
jeandras
1978 - 1996 Big Bronco
Apr 3, 2002 04:38 PM
