Brake Conversion
Old Jun 14, 2012 | 08:48 AM
1972RedNeck's Avatar
1972RedNeck
Brake Conversion
Originally Posted by 1972RedNeck
Originally Posted by OldHarley
I suggested that it might make sense for you to just plug the hole and make the switch to a pedal operated light.
That way when you convert to a dual braking system, that step is already done!
That will never happen. I like mine the way it rolled off the dealer's lot.
So as you can tell from the above conversation, I am looking at swapping a dual reservoir master cylinder on to my '66 F250 4X4. It has drum brakes all around.
I would like to use a MC with equal front and rear reservoirs. Is there such a thing? IIRC, I can take the rod out of a manual brake MC and put it in a power brake MC, right?
I have read that there is 3 different length rods. What is the best length/year rod to use?
I need a proportioning valve too, right?
All the old fords I've seen have a few coils in the brake line coming from the MC. Can I buy coiled brake line to run to the brake lines on the frame?
Old Jun 14, 2012 | 07:05 PM
1972RedNeck
Nobody's done this conversion?
Old Jun 14, 2012 | 08:31 PM
rogue40's Avatar
rogue40
It sounds pretty basic. Perhaps the early seventies drum/drum master cylinders and porportioning valve will work. I'm not sure since my upgrade was to disc/drum and I used a 76 master, p, valve and I-beam setup.
As for the coiled brake lines, I bent my own and hand coiled them around a can of pork and beans.
Old Jun 16, 2012 | 01:11 PM
1972RedNeck
Nobody else has any input?
Old Jun 17, 2012 | 08:54 AM
1972RedNeck
Really????
Old Jun 17, 2012 | 09:59 AM
66352F100's Avatar
66352F100
https://www.ford-trucks.com/forums/1...rake-swap.html
f100discs
Here are some links on that conversion.
Old Jun 18, 2012 | 12:46 AM
Jetcopterpilot's Avatar
Jetcopterpilot
Really????
What set up are you planning on using? Drum/Drum, Disc/ Drum, or Disc /Disc? If you go Drum/Drum, then no Prop valve is needed, any other format requires a prop valve... Yes you can use the Hydraulic brake light switch, just tee it into one of the lines as close to the Master Cylinder as possible.. Garbz is the guy to ask about conversions maybe he will chime in.. if not send him a PM .. pre 65 slicks can use the CPP dual master but I am not sure about 65 and 66 on.. If you have questions be very specific the more info we have the easier it is to give you a concise answer.... Have fun with your truck!
Old Jun 18, 2012 | 01:11 PM
1972RedNeck
Double post
Old Jun 18, 2012 | 01:20 PM
1972RedNeck
I have read that there are at least 3 different length rods. What is the best length/year rod to use?
Specific enough?
Why do I not need a proportioning valve? All drum/drum 4X4's after '66 had them. Right now I can lock the rear tires up while the fronts don't do very much.
Old Jun 18, 2012 | 01:48 PM
Jetcopterpilot
When I converted to the dual master cylinder, My brake balance improved radically it had been the rears like yours doing all of the work, but with the dual master it balanced out much better. Obviously you can add a prop valve if you feel you need one, but try it without first and see how it goes.... remember any and every pickup will want to lock up the rear end under heavy braking due to the weight balance difference... as you brake the weight and center of gravity shift forward, lightening th rear end up. making it easier for the rears to lockup... the fronts do about 60% + of the braking.
Tell me are your front Drums the cheaper single piston version that Ford used to do, or have they been upgraded to the dual piston like you have on the rear brakes? I converted my front single piston drums to dual piston a few months ago, and it made a drastic difference because it is pushing on both brake shoes in the front rather than just one...... my brake wear is very even now, and my front is more prone to lock than it was previously ...something to consider!
Old Jun 18, 2012 | 01:55 PM
Jetcopterpilot
Yes to Coiled Brake Line you can use it, but you can buy pre-manufactured Brake lines usually for not much more, and they save the headache of the bending process... My local Napa will make up the lines with all of the bends pretty cheaply if i just bring them the old lines... It saves the headaches
Old Jun 18, 2012 | 10:05 PM
garbz2's Avatar
garbz2
Your system needs a distribution valve. It provides fluid to the front and rear axles and in case of a failure slams the valve over center closing off the ruptured line. Any drum drum donor truck can donate on or you can buy new.
If you are doing discs you will need a prop valve.
If you are 100 percent stuck on a hokey juice switch use a 3/16 inverted flare by 1/8 female iron pipe Tee to mount the switch in line. Come out of the rear and place the tee a short distance with a short tube. Then continue to the distribution block.
Depending on what year you get the rods are removable and threaded. This can be modified to accommodate the pedal location. I just did a conversion using a 69 booster and master to a 65 using 3" brakes.
The rod you have on the 66 will actuate the master if you do not add a booster. You may need to take a bit off or add. I like to add a later model eccentric bolt to the pedal to alleviate this.
Garbz
ssme2
1997 - 2003 F150
Apr 18, 2020 06:48 AM
filthy6
Jul 18, 2015 12:50 PM
RC-Doktor
Apr 24, 2011 12:23 PM
65F100project
Aug 24, 2006 05:16 AM
