7° Reamer for knuckles
Old Jan 30, 2017 | 09:44 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by TheRedlines
I wound up getting a hold of wild horses 4x4 and they've added a reamer to the linkage order. My rent is already shot on the linkage so I figured I may as well. What really kicks my butt is that a late 77 F150 showed up in the yard today when I went to pick up the bluebulb cover for another member here today. It has everything I needed including disk brakes and power steering whole. I may go back and grab it after payday if it's still there. It certainly won't hurt to have the extras to help another out.thanks to all of you who've tried giving a hand.
Well, if ya wanna swap to discs like me, grab from that 77 the spindles, knuckles, and everything outwards.
On the flip side, grab the whole axle if it has a better gear ratio for your intended use. I'm running 35s and it's a lil doggy with 3.54/3.50 gears.
Old Jan 30, 2017 | 10:31 PM
TheRedlines's Avatar
TheRedlines
That's in my plans. I just hope someone doesn't beat me to the punch. I'm still 3 weeks away from having the cash to do it.
Old Jan 30, 2017 | 10:48 PM
HIO Silver's Avatar
HIO Silver
Dang Redline, ... that's what a credit card is for!!! Float it!!!
Old Jan 30, 2017 | 11:01 PM
TheRedlines
I suppose you're right. I should pick one up one of these days in a lot of ways it's nice not having credit.in others it sometimes sucks. That's a beautiful picture there! When you say it's a bit dodgy with 35"s and 350 gears... what do you mean? I have the same gears and 33"s planning for 35"s here in the future when I'm due. We aren't exactly rock crawling with a 1 to 1 T-case.
Old Feb 4, 2017 | 05:40 PM
TheRedlines
Ok so this Wednesday the Tierod/ adjustable draglink assy. came in from wild horses. Friday the 7degree tapered reamer came in from them as well. (It's an XKUT #5952 HS)
Today I had to run to Harbor Freight to pick up a couple jack stands and a Jack so I can get a straight shot at the knuckles with the tires off. A few good whacks with the BFH and the old assembly is off. It turns out the stock 1974 Pitman arm has the same size hole as the later so will not need reaming. The knuckles of course are a different story. Luckily they have more than enough meat to take the reaming and be plenty strong after. I'm starting to come down with a fever and runny nose now. Taking a quick coffee break and I'm hoping I'll have it in and set by evening. Then I can worry about getting rid of this crap tomorrow and be ready for work monday.
Old Feb 4, 2017 | 08:07 PM
HIO Silver's Avatar
HIO Silver
Not dodgy... "doggy". Meaning, gearing is a tad numerically low for 35s. I figure 3.90s would be in the sweet spot.
Thanks for the info on the pitman arm.
And yeah, I too was concerned about enough meat on the steering arms.
Old Feb 4, 2017 | 11:10 PM
TheRedlines
Holy moly! I worked at reaming those out by hand for a good 45 minutes before I threw in the towel and ran to lowes for a 1/2" corded Drill. I just couldn't get it to bite by hand. It's all assembled now though adjustments will wait for sunlight tomorrow. We used to set the Jeeps at 1/8" Tow in. Does that sound about right for our trucks? The Drag link will just be centering the wheel once the rest is in shape.
Ah ok. With 33"s it seems just right for starting in 2nd. 1st only gets used if I'm hauling a ton and pointed uphill or if I want to idle out of somewhere.
Old Feb 4, 2017 | 11:44 PM
HIO Silver's Avatar
HIO Silver
Really? My Xkut cut like butter... firm square pressure while turning. Hmm.
Yeah 35s starting in 2nd gear with 3.50.gears is an issue. Dealing with rolling hills requires downshifting... and I don't 'speed' in the rig either.
Old Feb 5, 2017 | 12:14 AM
TheRedlines
I do have to say the Xkut dit very well once I chucked it up in the drill. It was a piece of cake. I will admit, I didn't have a proper tap holder but was using a 3/8" socket and ratchet. Regardless, I got them reamed out nice and neat in the end. Regarding gears, looks as though you and I both will be looking to regear sometime here in the future. Maybe even add a limited Slip
Old Feb 5, 2017 | 09:14 AM
HIO Silver's Avatar
HIO Silver
I used the large T handle from my tap n die set. I guess that made the difference.
My rig has Trac-Lok...... but here's my to do list... swap the NP435/Dana 21 combo to a NP435/NP205 combo, swap to discs, and re-gear.
Old Feb 10, 2017 | 08:41 PM
TheRedlines
So I've got a great update. All went very well and the crisis was averted. The old stock TREs are in the trash dumpster and the truck is now tracking beautifully. The XKUT 7° Reamer worked great and is still in perfect condition. Whoever needs it next, cover the shipping and I'll send it out to you. Be respectful using it and when finished, send it off to the next person in need of it and we can keep this ball rolling.
ROKRAWL
May 1, 2012 11:22 PM
704 dentside man
Nov 15, 2010 02:22 PM
mando jake
15
Feb 13, 2009 02:10 PM
strawboss
Aug 26, 1999 07:33 PM
