77 4x4 tie rod swap to 78/79 style???
Hi. I just got a 77 150 a couple of months ago and am about to put a 4.5" kit on it. i was told the steering should be swapped to the 78/79 style so i got the tie rods and adjustment sleeve for the 78/79 style to install. Will my truck need to be modified to accept these or will they simply bolt up? Thanks in advance.
Brett
Brett
76-77s use the Y-style steering whereas the 78-79s use the T-style steering. Going with the T-style reduces the number of moving parts and is less susceptible to bump steer.
If you're going with a 4.5-inch lift, I suggest both the dropped pitman arm AND dropped trackbar bracket, RA drop brackets, 2 to 4 degree C- bushings, and new poly bushings everywhere. IMO, the "best" kit out there is from BDS Suspension.
Thesteeleboy
03-11-2016 11:05 PM
coz
10-09-2010 11:29 AM
Spooky
10-26-2002 01:44 AM
FB79
09-28-2002 02:49 PM
