HELP! Fuse #8 keeps blowing
Old Jan 29, 2017 | 07:27 PM
elderivers's Avatar
elderivers
Angry HELP! Fuse #8 keeps blowing
So i have been fighting this for over a week.
Last week I took of in my 2001 f-350 7.3L, I rolled down my window to close the garage door. the radio stopped working and then the window would not go back up. I opened the door and the door ajar lite or chime did not work. a few seconds later it started working and closed the window. However the radio did not work. I got to work and pulled the fuse. #8 was blown i replaced the fuse and turned the key. it blew again. Thinking the radio was causing the issue i pulled the radio disconnected it and tried it again. the fuse blew again.
A question later on Junstanswer The tech advised to unplug the fuel bowl heater. I disconnected the fuel bowl heater and installed a new fuse and that blew. He then advised that the GEM is bad and to remove it and look for any moisture or sings of water leakage. There were none.
I thought if I reconnected the fuse box and left the GEM disconnected turned the switch to auxiliary I would be able to confirm that the GEM was in fact the problem... I asked the tech and said it would be a great way to isolate the problem. So i reconnected the fuse box and the fuse blew again. The tech from justanswer has not responded to me in a several hours. I have no idea what to check for next.
Old Jan 29, 2017 | 07:45 PM
DieselDenny's Avatar
DieselDenny
I've heard of this infrequently.
Example. Cross the same set of railroad tracks everyday. Truck dies in the same spot every morning on the way to work and on the way home.
Pass under a cell tower Ditto.
If you can change the frequency on your opener, give that a shot.
Does it happen ANYWHERE else???
Strange shi.....stuff, but we have more crap under that dash than Apollo 13.
Just sayin.
Denny
Old Jan 29, 2017 | 07:48 PM
DieselDenny
BTW,
The trucks in your sig have enough miles to get to orbit and your new here????
What are you doing that the rest of us aren't??
Denny
Old Jan 29, 2017 | 07:52 PM
DieselDenny
Just reread and reread. No I haven't been drinking................
It's looking pretty good at the connection at the door. Same fuse your radio's tied into??
All'right I'll have another one.
Hats off
Denny
Old Jan 29, 2017 | 08:10 PM
elderivers's Avatar
elderivers
Lol, not sure I am doing anything any different with my rigs.
I have Been a paying member as of last year. Subscriber since 2006.
This issue has only happened this one time. Have not been able to get it sorted out. Manual shows #8 as the radio/headlight switch. Head lights work fine. Every thing works now but the radio and that damn fuse. I need to listen to something to keep the road rage at bay
Old Jan 29, 2017 | 09:55 PM
garydmundy's Avatar
garydmundy
fuse #8 blows
Just because it wasn't the "radio" doesn't mean it's not the wiring going to the radio. Follow the wiring and see if you can find a short to ground. Probably somewhere where it it rubbing against metal.
Old Jan 29, 2017 | 10:02 PM
elderivers's Avatar
elderivers
I will check the wiring again.
Old Jan 30, 2017 | 12:08 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
You can narrow your search on the wiring by finding the 12v wires. Tons of wires on the back of the radio, but only 1 or 2 of them would be candidates for a short to ground. I had a crimp come loose on mine that shorted to ground after I installed a new radio. Of course, that was easy to find...
Old Jan 30, 2017 | 05:43 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Originally Posted by elderivers
So i have been fighting this for over:
Pull the drivers door cover and check wire bundle inside. The door plunger will hit the wires if the holder has failed.
Good luck!
Old Jan 30, 2017 | 07:13 AM
SparkyAl's Avatar
SparkyAl
Just as a quick reminder from an old Electrical Engineer - You may be tempted to just put in a larger fuse that doesn't blow and call it good, but this is a BAD idea, and a good way to have an electrical fire. Fuses protect wires, not equipment, and are sized to prevent the system from drawing more current than the wire can handle.
Old Jan 30, 2017 | 07:27 PM
elderivers's Avatar
elderivers
Thanks, for the tips. I have no idea what I did this afternoon. I checked continuity from Fuse 8 to the power along the pink/black wire. I also had continuity to ground. So the search was on. I checked connections and plugs and it was working. I tried for 90 min to duplicate the issue and was not successful. Will wait until the next hiccup.
Old Jan 31, 2017 | 02:45 PM
SaintITC's Avatar
SaintITC
Is it the wife's truck?
Topkat69
Electrical Systems/Wiring
Dec 31, 2014 10:22 AM
cldomson1
Jan 31, 2011 05:19 PM
bigdaddyII
Jun 16, 2008 05:57 PM
Whitey Ford
22
Feb 21, 2008 04:00 PM
mountaineerman04
Oct 7, 2004 11:07 AM
