Engine won't turn off
Old Jan 28, 2017 | 11:55 AM
AKF III's Avatar
AKF III
I've never run into this before so I'm hoping for some advice. My new to me 1973 F100 will not shut the engine off with the key. The engine is a stock 360 with points ignition. When the key is turned off it kills things like the fan motor and radio, but the engine continues to run. Any input would be greatly appreciated.
Old Jan 28, 2017 | 12:54 PM
HIO Silver's Avatar
HIO Silver
Double post... look below.
HIO Silver's Avatar
HIO Silver
Typically that means a bad ignition switch. Replace it.
Old Jan 28, 2017 | 01:54 PM
nzirbel's Avatar
nzirbel
A bad solenoid will do that too. Next time it does that, give the solenoid a whack. If it shuts off replace the solenoid. And my advise is to pay extra and get the premium replacement.
Old Jan 28, 2017 | 02:13 PM
AKF III's Avatar
AKF III
Thanks for the replies. I'll take a look at both.
Old Jan 28, 2017 | 09:11 PM
PapaBearYuma's Avatar
PapaBearYuma
How are you getting it to turn off now? I'd pull the coil to distributor wire
Old Jan 29, 2017 | 06:56 AM
AKF III's Avatar
AKF III
I have just been putting it in fourth gear and stalling it out. I have noticed that it will turn off with the key before the engine heats up.
Old Feb 16, 2017 | 05:18 AM
AKF III's Avatar
AKF III
Well I finally got some time to look at this problem. I replaced the ignition switch and the starter solenoid and it still will not turn the engine off when it is warm. As long as the engine is cold, initial start up, the switch will turn the engine off. But after it warms up the engine stays running when the key is off and the power to the cluster is off when the key is off. Any ideas?
Old Feb 16, 2017 | 07:31 AM
F250_Super_4X4's Avatar
F250_Super_4X4
So I have seen this 1 out of 1000 times but it has happened to me before. Add a rectifier diode, at least 3A to your alternator exciter wire -or- run the exciter wire straight to your ignition switch ACC output. This will isolate the circuit and remove any feedback that may be keeping your engine running. A rectifier diode, $0.45 at radio shack, is basically an electronic check valve only allowing electricity to run one way to your alternator therefore a charge cannot return to your ignition system.
f100popeye
Apr 25, 2014 08:05 AM
hafa adai
Jun 4, 2010 04:08 PM
csb912
May 10, 2007 01:04 PM
ford fisherman
Feb 18, 2005 07:15 AM
TallPaul
Electrical Systems/Wiring
Aug 25, 2004 08:28 PM
