New here need help please
Old Jun 3, 2010 | 11:36 PM
hafa adai's Avatar
hafa adai
I have a 75 f100 4x4 390 engine when i turn off the key the engine is still running and no matter what i do it will not shut off.i had to play with the key finally it turned off.i nevered had this problem before, has anyone had this problem? thanks for you help.
Old Jun 3, 2010 | 11:49 PM
spudgunman's Avatar
spudgunman
if you had to play with the key I would assume that you have a ignition switch problem
Old Jun 4, 2010 | 08:27 AM
fmc400's Avatar
fmc400
MSEE
I agree, sounds like the ignition switch. They do wear out over time (I recently had to replace mine because the accessory circuit was cutting out when the key was on).
Old Jun 4, 2010 | 08:47 AM
mikeo0o0o0's Avatar
mikeo0o0o0
X3 on the ignition switch. They aren't that expensive and relatively easy to replace.
Old Jun 4, 2010 | 03:25 PM
dogmantra's Avatar
dogmantra
X4.
I've had this happen on many of my vehicles over the years. New ignition set isn't too spendy or hard to manage.
Old Jun 4, 2010 | 04:08 PM
hafa adai's Avatar
hafa adai
Thanks to all you guys that reply to my post i will check and hope that's all i need to fix the problem.i like this forum lots of info here. thanks again
