Sponsored by: Real Truck
Second High Mount Backup Camera
Old Jan 24, 2017 | 09:59 PM
rdlouks's Avatar
rdlouks
I would like to add a second backup camera to my 2016 F-350 Super Duty to assist when hooking up to my fifth wheel. It is a Crew Cab with the Factory Tonneau Cover so my view of the hitch is blocked. I would like to add the third brake light high mount camera and be able to toggle between my OEM/Tailgate Camera and the High Mount. I have found a couple that claim they will work but both require tapping into the main connector on the back of the display, but not quite sure how to open it up. Accessing the connector is not a problem, just getting it apart without breaking it is the question. The "Lockpick" system has not been tested/certified for the 2016 model. Any ideas/assistance?
Old Jan 24, 2017 | 10:43 PM
Pocketlint's Avatar
Pocketlint
FTE member acecase just did something like this and even had a parts list of the things he used. Might want to give it a read , some info or parts could be of use to you in your project. Thread link is below
https://www.ford-trucks.com/forums/1...ew-mirror.html
Old Jan 25, 2017 | 09:27 AM
rdlouks's Avatar
rdlouks
Thanks Pocketlint.
Old Jan 27, 2017 | 09:07 PM
ufvj217's Avatar
ufvj217
i too want to add high mounted camera(s) on my 04 f350, and i also just came across the thread linked above. should help me out a great deal!
rdlouks, you should update this thread when you decide on an install for yourself.
herojeep
Feb 2, 2018 08:25 PM
rdlouks
Dec 22, 2016 07:40 PM
Technologiq
Jul 12, 2016 08:55 AM
Balderman72
6.4L Power Stroke Diesel
May 1, 2015 09:58 PM
Jspafford
Dec 8, 2006 11:06 PM
