Regarding fan shrouds....
Old Jan 23, 2017 | 10:58 AM
351Cleveland C4's Avatar
351Cleveland C4
I'm in the market for a new fan shroud. Mine is pretty busted up.
As most of you can tell, I've got a 351, which wasnt ever used in the trucks. So what I have is the original 302 fan shroud. Being that the 302 is shorter, the shroud sits lower.
So, what I'm getting at is, did the FE trucks have a fan shroud shape that could possibly work with my 351? Or does anyone have any ideas of what else might work?
Old Jan 23, 2017 | 11:20 AM
Mikulh's Avatar
Mikulh
I've got a dentside fan shroud that I pulled off a parts truck that I plan to put on my bumpside. I haven't actually tried to bolt it up yet, but it sure looks like it should work.
Old Jan 23, 2017 | 11:31 AM
HIO Silver's Avatar
HIO Silver
Why not upgrade to a Lincoln Mark Viii e-fan?... integral shroud and its massive diameter will suck a cat flat to the grill.
Old Jan 23, 2017 | 11:54 AM
JEFFFAFA's Avatar
JEFFFAFA
Hio has a good point. Is this the one you have now? (borrowed from DC web site)
Old Jan 23, 2017 | 04:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by JEFFFAFA
Hio has a good point. Is this the one you have now? (borrowed from DC web site).
El Jeffe: Carpenter goofed, this is the WRONG ID number for this shroud.
D3TZ-8146-B = Marked on upper left corner: D3TA-8146-CA
D3TZ-8146-C (replaced C8TZ-8146-K) .. 360/390 Fan Shroud-Use with standard/xtra cooling & A/C radiators.
Marked on upper left corner: C8TA-8146-S or D3TA-8146-DA / 1968/76 F100/350.
Old Jan 23, 2017 | 04:52 PM
JEFFFAFA's Avatar
JEFFFAFA
Ah. So maybe I should ask it another way. Garret, what are the engineering numbers off your existing shroud that fits?
Old Jan 24, 2017 | 10:45 AM
351Cleveland C4
I am not sure. Where would they be located on it?
Old Jan 24, 2017 | 11:11 AM
NumberDummy
ID engineering number located on the the upper left (drivers side) corner of the shroud.
If it's D3TA-8146-CA or D3TA-CA: 302 / If it's C8TA-8146-S or C8TA-S or D3TA-8146-DA or D3TA-DA: 360/390.
Old Jan 24, 2017 | 01:10 PM
351Cleveland C4
The only markings I can find on it are D0TA 8146. The ford oval, and Barnum Bros (something)
All on the passenger side
Old Jan 24, 2017 | 01:17 PM
Brian1971f100's Avatar
Brian1971f100
Would that be Barnum and Bailey Ringing Brothers Circus?
Old Jan 24, 2017 | 01:20 PM
NumberDummy
It's probably D0TA-8146-A = D0TZ-8146-A replaced by D3TZ-8146-B
1969/79 F100 & 1975/79 F150 302 .. use with standard/xtra cooling & A/C radiators.
btw: Ringling Bros. and Barnum and Bailey Circus is about to "fold the tent" for the last time.
After the few remaining 2017 engagements are finished, so will they be...out of business after 132 years.
351Cleveland C4
I have no clue haha
I assume it was an outsourced part.
Old Jan 24, 2017 | 01:23 PM
351Cleveland C4
Thanks dummy.
So then, it's pretty much the correct shape. I suppose I may just have to order a new one when I put in my upcoming big order from NPD or DC.
Old Jan 24, 2017 | 02:51 PM
JEFFFAFA's Avatar
JEFFFAFA
DOTZ8146A shown at:
McDonald Obsolete Parts
Part Number DOTZ-8146-A
Seller:McDonald Obsolete Parts
Phone (812) 359-4965
Price:Request PricingEmail:Send Seller Email Inquiry
Quantity:1
D3TZ8146B shown at:
Miller Obsolete Parts
Part Number D3TZ-8146-B
Seller:Miller Obsolete Parts
Description:FAN SHROUD
Phone (607) 722-5371
Quantity:1
Nos Parts Source *Fo
913.220.5746
xGreen Sales
(800) 543-4959
xDennis Carpenter Ford
704-786-8139
Lebowskii
2015 - 2020 F150
Mar 14, 2019 12:57 PM
Bankrupter
28
Nov 9, 2013 06:35 PM
460
Jun 24, 2007 02:06 AM
volfan16
Garage & Workshop
May 17, 2004 10:55 AM
