Engine fan and shroud questions...
Hey all, I'm thinking that the stock fan has been changed out for some other fan on my '78 F150 with a mighty 302. Did the stock fan have a fan clutch? Were any trucks ever made without a fan shroud in 1878? Are fan shrouds engine specific?
Here are a couple pics...
http://i44.photobucket.com/albums/f2...6-22-07002.jpg
http://i44.photobucket.com/albums/f2...6-22-07001.jpg
I was looking around a couple days ago and Jeff's Bronco Graveyard has a fan shroud for these trucks with a 302. 85 bucks...
http://broncograveyard.com/bronco/i-...rd_cooling.htm
The fan is wrong, it doesn't even resemble a Ford fan with those curled edges.
You need a fan that's 18 1/2" in diameter. There are 100's of Ford car/truck fans from the 1960's/1970's/1980's that will work. Most are 5 blade, some are 7 blade = with or without a fan clutch.
Fan Shroud: D8TZ-8146-B is the correct shroud that Jarmafenser posted, but it's obsolete, and finding one will be tough. Use this fan shroud instead >>> D3TZ-8146-C It will fit, and it's still available from Ford. FTE sponsor DIRECTFORDPARTS shows it as $109.63 List / FTE member net: $77.09.
Originally Posted by Mil1ion
I'm pretty sure that 4 blade Fan shown is from my 289 Mustang.
It looks just like it.
But the fan in the above picture has curled blades. Never seen a Ford with blades like that. Looking at the fan head on, it looks identical, until you look at those scooped blades.
Thanks for the (current) part numbers for the shroud. My blade is quite small... maybe about 14" at the most. I'm really suprised how well it cools for being as "wrong" as it is.
Before creating this post I looked at the fan blade for a Ford part number, but could find none, which led me to believe this may be an old-school aftermarket fan, possibly from before the advent of the flex fan.
