Pushon connector for temp sensor?
Old Jan 22, 2017 | 01:12 PM
beartracks's Avatar
beartracks
90 Degree Female Molded Connector - Wiring Products
Any source for these? $5 is kind of high.
Old Jan 22, 2017 | 01:22 PM
78fordguy's Avatar
78fordguy
Junkyard, mostly all obd1 fords used that 1 wire connector. Look at 87-99 OBS f150-350 they probably won't even charge you.
Old Jan 22, 2017 | 02:25 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Either that or use a plain old ring terminal and an 8-32 nut (if it's OEM)
Old Jan 22, 2017 | 05:37 PM
BigSexy78's Avatar
BigSexy78
In a pinch you can use a butt connector. Put the wire on one end of the butt connector and push the other end over your terminal.
chadgt
1983 - 2012 Ranger & B-Series
Nov 28, 2018 10:41 AM
bricktron
Aug 30, 2014 10:45 AM
jeffdoerr
Feb 15, 2009 12:22 PM
oem78
Dec 4, 2006 10:06 PM
Forddrof
16
Aug 29, 2002 07:39 PM
