Connector for engine temp sensor
Old Aug 24, 2002 | 06:39 AM
Forddrof's Avatar
Forddrof
I have a '72 F100 w/ 390 and the wire to my water temp sensor has become brittle and cracked exposing wire. I patched in some better wire but I was wondering what would be the best connector since I don't have the "elbow" type. Will a ring or Y connector work? Also, the "screw post" on the sensor turns, is this ok or is it damaged? Thanks!
Old Aug 24, 2002 | 07:24 AM
1968F250LWB's Avatar
1968F250LWB
Same Problem here.
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
Old Aug 24, 2002 | 10:16 AM
Mike W's Avatar
Mike W
If the post on the sensor turns, it will probably go open. How about using a nut with a spade type connector? I once checked a sensor with a temp gauge. They are linear up to half scale. Above that, they move less with an increase in temp. So full scale is really hot.
Old Aug 24, 2002 | 08:47 PM
Forddrof's Avatar
Forddrof
Well, sure enough the temp gauge is now pegged so it's open. I'll be replacing it. Thanks for the help anyway!
Old Aug 25, 2002 | 05:48 AM
1968F250LWB
So if the post spins it's open. Good info. Don't know if mine does yet. I needed the help with the connector. Thanks guys. When you replace your sensor remember not to use anything on the threads as they provide the ground.
Russell
1968 F250 LWB 300-6
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
Old Aug 25, 2002 | 07:24 AM
Forddrof's Avatar
Forddrof
When you replace it can you just unscrew it or will you have coolant all over the place?
Old Aug 25, 2002 | 11:57 AM
Mike W's Avatar
Mike W
You will have coolant all over the place. Drain about 1/2 gallon first.
Old Aug 25, 2002 | 04:55 PM
hawkrod's Avatar
hawkrod
on a stock ford sending unit with a single post the terminal will spin as it is just a contact. if it were open the guage would not peg, as a matter of fact it would not move as power would not flow. if the guage pegs you have a grounded circuit not an open circuit and you can check it by unplugging the sensor and see if it goes down. if not then look for damage to the wire. if it goes down then replace the sender. hawkrod
Old Aug 27, 2002 | 04:42 PM
BB's Avatar
BB
I think he was talking about the threaded post itself spinning, not a good thing. You’re right, with the wire shorted to ground, the needle will peg. With the wire open, the needle will drop to nothing.
Mike, you can’t check the temp. sender readings with an ohmmeter and directly correlate them to temperature. The problem is the current that’s pulsed into the sender from the IVR causes a self-heating effect inside the sender. It internally heats the resistance of the thermistor, causing a bias. This is a common occurrence with temperature sensing devices. Fortunately, this self-heating bias is already taken into account in the circuit design so you never see or notice it.
Barry
Old Aug 27, 2002 | 05:19 PM
Forddrof's Avatar
Forddrof
I replaced the sending unit and all appears well now. Thanks for all of the help.
Old Aug 27, 2002 | 10:18 PM
rebocardo's Avatar
rebocardo
For my senders and contacts on the starter relay, I like to replace the elbows with round lug connectors and secure them with little nuts and a plastic hood. I hate when the oil pressure sender falls off or loses contact because it stalls the truck.
Old Aug 28, 2002 | 10:35 PM
hawkrod's Avatar
hawkrod
i am talking about the threaded post spinning. it does not spin when new but original ford ones will spin with age and still work. the post just sits on the internal parts and is not soldered so the post spins. obviously if this was not true his guage would not have read at all because current was still flowing allowing the guage to peg. when i was working at ford there was a TSB on this because mechanics were replacing them by the thousands and ford didn't want to cover them as this is not considered a defect! hawkrod
Old Aug 29, 2002 | 12:03 AM
BB's Avatar
BB
Hmmm…the post on the original sender in my truck would spin, and it read low too. Hey maybe you can answer why I needed a special temp. sender that only the Ford dealer has (special order) for $60? The replacement senders from NAPA and the others don't work right and all read high. It has to do with the serial number of the truck, I forget what the breakpoint was. They called it a "red top" because the insulator is red on top. My gauges test out ok with the 10, 22.8 and 73 ohm resistor checks just like in my other Fords.
Hey, when did you work for Ford? Do you remember when that TSB came out? I used to work for L/M and still have a lot of those parts and service newsletters.
Barry
Old Aug 29, 2002 | 08:18 AM
hawkrod's Avatar
hawkrod
the TSB was in the early 80's. i worked for F/L/M dealer until mid 84 when the owner retired and the dealership closed. the different color tops make the guage read in different ranges to soothe the customers concern over vehicles running too hot or too cool. by changing the senders ford is able to set all vehicles up with the same guages and wiring but in a truck the sender may be a little slower to respond and may not send the guage as high or low due to the larger cooling system which gives a little more capacity and the uses of the vehicle which may cause concern under normal conditions. an example that comes to mind is a truck that has a 180 thermostat and a car with a 190. since the guages have the same wiring and mechanism with a different face and needle they will read exactly the same. that is to say the car with the 190 has the guage reading higher than the truck. to make them both sit in the middle ford uses senders with different calibrations. hawkrod
Old Aug 29, 2002 | 10:53 AM
William's Avatar
William
I'd replace the sending unit, they are cheap and monitoring engine temprature is important. I use a double nut with lock washer and ring connector on new wire. But I'm picky about this stuff and like to fix things once, permanently!
William in Atlanta
