DRW Conversion?
Is it as simple as ordering an arrowcraft kit? Their website is hard for me to understand... but I wonder... will my stock bed work? Will I need bolt on fenders?
I think my Sterling 10.5 axle was used in older, gasser, F350 DRW's... don't know how well it would do but would prefer not changing it... or the gear ratio (I have 3.55).
Finally, I know I'd need to change out my front wheels as well so I would only need to carry 1 spare.
Anything else? I guess for me, being forced to change the bed or swap out for a Dana axle would be a deal breaker...
Purchasing a DRW axle will probably be the easiest part. Things to consider:
leaf spring mounting points; shock mounting bracket alignment, rear gear ratio will need to match front gear ratio (or change front gear ratio); will an older axle pinion match up to existing driveshaft mount; ABS sensor integration; will brake calipers on replacement axle integrate with current system calibration; fender extensions, possible exhaust re-work and I'm sure several other things that don't come to mind.
Would probably be better off selling your truck in the private market (will get way more than a trade-in) and just upgrade to a 350 DRW.
I didn't understand the towing charts, and thought the higher end trucks were much more expensive than they were...so never really considered them.
Normally I buy the biggest, most expensive thing on the market. However, my wife was not a fan of me buying a truck that cost significantly more than our first house, and when my F250 hit 81-ish-K for tax, tag, and title I quit looking for more expensive trucks.
F250's are what they have on the lots, and maybe it's just me, but I've not found the bigger, badder, higher-end trucks on the lots near me. So F250's is what I had to look at, and as mentioned they were very expensive.
The towing charts are really confusing. When I started looking at them there was a lot I didn't understand, and it looked like I could tow more than enough.
I joined this forum a week or two before I pulled the trigger on my F250.
I love it, and it's the most beautiful, incredible truck I've ever owned.
But hanging out on this forum, I've learned that my 'legal' towing numbers are far below any of those charts. (I've burned up the 5th wheel forum comparing why, and coming to the realization that 250/350 are can be made into the same truck easily -- and I'm in the process of doing that.)
While I know on paper that my modified F250 can and will pull every bit as safely (pound for pound) as the exact same F350 stock off the lot... the GVWR police are... EVERYWHERE.
- these forums
- the big truck and rv youtube channel (interesting because he admits the F250 and F350 are the same truck with better suspension and more air in the tires) yet he just made a 20 minute video admonishing anybody who tows past their GVWR.
- Every manufacturer of airbags, helper springs, etc. tells you it's ONLY to prevent squat and to never exceed GVWR/GCWR
- Now, come to find out, 3 states are stopping people and giving them over weight tickets
All these 'weight police' are like a soothsayer that keep whispering... you'll be sorry...you'll be sorry. So, I don't know. A part of me just wants to say "ok. we all agree on the physics...but you all keep telling me that judges, juries, and police officers are human and unpredictable...won't look at the physics...will only look at the sticker." Sigh... I think I'd just like to put all of that out of my mind and "be within my numbers." Short of being able to do that... if I ever do end up arguing my case... I think a DRW F250 would fare better...and I think it looks better...and it would be a pretty unique thing.
Along this journey I've learned that DRW's make the best towing platforms and I want to start doing a lot more towing.
Also, purely emotional, I think the DRW's look more bada**. I always have, but for reasons above (and me being worried about parking it) I didn't go there.
Now I have to park my F250 CCLB like a dually anyway.
And come to find out the bigger trucks are not nearly as 'more' expensive as I'd thought.
So, yeah, if I could snap my fingers and go back to November, I'd buy an F450.
Plus, now you've lived with your SD for a while....I bet there are a few things you would order differently....which you could go ahead do and if you reorder.
He did say I wouldn't notice any difference unless I opted for a DRW.
So thanks for this suggestion. I'm going to ask him, out of curiosity, what the truck in the pic would cost me. I'll post the answer here. Thanks
