2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Bandaids? Patch panels? Panel Stiffners? Maxi-Pads? What am I looking at?
Old 01-18-2017, 04:05 PM
gotroxs's Avatar
gotroxs
gotroxs is offline
Ok so I was crawling around the bottom of the truck looking for a place for my air compressors.
Found 2 of these "things" attached to the inside of the passenger side truck bed. This is the inside of the bed skin.
On the other side right by the fuel spouts were a few more.
Just curious, are any of these guesses correct? Bandaids? Patch panels? Panel Stiffners? Maxi-Pads?
And those bumps in them are stiff like there is something underneath them.
Old 01-18-2017, 04:21 PM
silver_pilate's Avatar
silver_pilate
silver_pilate is online now
No idea, but my WAG is some sort of vibration/harmonic/sound dampener.
Old 01-18-2017, 04:23 PM
silver_pilate
By the way, did you ever locate a suitable place for your compressors? I've been under the truck for other purposes but didn't really look for a place for a compressor. Is there enough room above the spare? There's lots of lines and looms on the frame rails of these new trucks where I mounted in the past.
Old 01-18-2017, 04:27 PM
gotroxs's Avatar
gotroxs
gotroxs is offline
I think I might go the lazy route and mount it under my toolbox with maybe the tank in the tool box.
Old 01-18-2017, 05:36 PM
Bread Truck's Avatar
Bread Truck
Bread Truck is offline
"Nitto, Inc.’s Lakewood, NJ facility is a premier manufacturer of acoustic, structural and sealing materials for the automotive industry. Our lightweight structural products make cars run quieter by reducing road noise and improving fuel efficiencies."
Either that, or they are absorbent pads for when our transmission lines blow?
Old 01-18-2017, 05:40 PM
gotroxs's Avatar
gotroxs
gotroxs is offline
In that case they should wrap the whole truck in it.
Old 01-18-2017, 06:23 PM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
NVH mitigation
Old 01-19-2017, 01:40 PM
mlsjohn's Avatar
mlsjohn
mlsjohn is offline
I mounted my wireless firestone F3 air compressor on a 1/4 inch 8x11 inch flat aluminum plate on the cross member behind the trans. On the left side of drive shaft. I used the 2 existing holes in the cross member and drilled 2 holes in the plate to fasten it to cross member with 1/2 in bolts and large flat washers. Then placed the components on the plate to mark the holes to fasten to, so to be on the outside of cross member so I could use bolts with nuts. Using this location it is between the frame and away from being splashed by dirt and water. The parts will be mounted upside down, talked to firestone and it does not matter what way they are mounted
Itsmyford
11-07-2018 12:56 PM
emgee
04-01-2013 09:44 PM
firefighter15
1999 to 2016 Super Duty
05-03-2012 03:02 PM
Rocksetter
Paint & Bodywork
22
02-22-2010 08:46 AM
ama chur
06-13-2003 12:00 PM
Quick Reply: Bandaids? Patch panels? Panel Stiffners? Maxi-Pads? What am I looking at?
