Im lost NEED HELP
Old Jan 18, 2017 | 07:33 AM
Greatwhite94's Avatar
Greatwhite94
Im lost NEED HELP
(1994 f250 7.3 idi na)So a few weeks ago i did a fuel filter replacement, along with the standard ATF treatment and let it sit for 48hr. The night after i started her up and ran her like hell when i came to a stop and put her in neutral and let her idle she will start to what seems as a misfire and can only be fixed by giving a good 1500rpm rev and than she will idle correctly. But when i am accelerating there is no loss of power and no random white smoke no signs of timing or blown head gasket. Now 2 weeks later still having same problem alot less frequent now, now when i start her up(even after being on a block heater all night) she will start and than randomly die unless i start feeding her fuel for a couple pumps and than she will be fine. So please someone help im lost on what it could be!
Old Jan 18, 2017 | 08:54 AM
MtTheJeffro's Avatar
MtTheJeffro
Did you maybe bump the timing advance switch and it's not getting a good connection?
Pic from web, actually another user on these forums...not mine.
Old Jan 18, 2017 | 08:55 AM
tjc transport's Avatar
tjc transport
i ain't rite
sounds like air intrusion. when cold remove the fuel filter and see if it is full or half empty.
Old Jan 18, 2017 | 09:51 AM
Greatwhite94
it looks like its making a good connection i looked at it and nothing seems loose or out of place
BomerFett
17
Jan 5, 2012 03:38 PM
connor_warren59
Oct 10, 2010 06:03 PM
boggerted
Apr 13, 2010 09:46 PM
Halfbad
18
Feb 6, 2010 12:39 PM
LCAM-01XA
Jan 1, 2009 09:34 AM
