Need help no spark
Old Jan 17, 2017 | 10:32 AM
Trevor1423's Avatar
Trevor1423
Need help no spark
Hello I have a 87 Ford F-150 4.9l I am have replaced everything under the sun on this truck and still not getting any spark can some please shed some light on this mystery lol thanks in advance
Parts replaced distributer ICM PIP sensor coil and repaired the PCM (supposedly) and plugs and wires
Old Jan 17, 2017 | 02:17 PM
joey2fords's Avatar
joey2fords
when you turn the key to "run" does the fuel pump run for a second then shut off ?
have you tried pulling codes ?
Old Jan 17, 2017 | 04:28 PM
Trevor1423's Avatar
Trevor1423
Yes the fuel pump kicks on and off and when I am working on for a while I can smell fuel coming out of it and for some reason I can't figure out how to jump out the contector for the codes
Old Jan 17, 2017 | 05:43 PM
chesster51's Avatar
chesster51
I had a similar problem, mine was more sporadic, turned out to be the ignition switch under the dash on the steering column. That fixed the problem for about 6 months and back to no spark. Replaced the distributor and all has been fine since.
Old Jan 17, 2017 | 05:54 PM
Trevor1423's Avatar
Trevor1423
Would it still turn over when you had the problem and everything still came on?
Old Jan 17, 2017 | 06:18 PM
chesster51's Avatar
chesster51
Yes, lights and everything
Old Jan 17, 2017 | 06:24 PM
Trevor1423's Avatar
Trevor1423
Were you getting power to the distributor still i am getting 12v from the coil to distributor?
Old Jan 17, 2017 | 09:24 PM
chesster51's Avatar
chesster51
If I recall, I was getting power to the distributor, the problem was internal to the distributor itself. Think I paid about $100 for a new unit at Advance Auto Parts.
HoosierDaddy1
Jun 12, 2017 10:51 AM
David_09
Dec 12, 2015 07:38 AM
Desireg
Sep 25, 2015 05:22 PM
Peter15
Aug 20, 2012 07:38 PM
Rothschild
15
Aug 11, 2009 04:58 PM
