Sponsored by: Real Truck
Engine Swap
Old Jan 15, 2017 | 12:40 PM
carpenterbug's Avatar
carpenterbug
Engine Swap
I have a 1999 F350 with a 5.4 and 5 speed manual. The engine has over 200,000 miles and I am thinking about replacement. Could a carbureted 302 or a 351 Windsor be used. I am fed up with the computer controlled systems. Thanks.
Old Jan 16, 2017 | 08:52 AM
EDC8008's Avatar
EDC8008
You can pretty much do whatever you want but I lik so many other's will ask "Why???" Just like I ask my customers in the power industry, How much money and how much time do you have. You'll decrease available horsepower and/or mileage for the equivalent horsepower.
Concerns will be and many people say it that emissions doesn' effect them, but you go backwards to a carb you'll have issues with that. I've seen it get more and more stringent and it'll only get worse.
Old Jan 16, 2017 | 10:44 AM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
Yup. As much as they can be a PIA, better to learn what there is to love about the computer controlled engines and focus on that. They actually are pretty reliable (although yes, you can be SOL when they fail if you don’t have the right tools) and the advances in emissions, HP and economy they have introduced are pretty amazing. I drive my wife’s EcoBoost Explorer and have to shake my head - if 40 years ago you had told me that I’d have a good sized vehicle with a 215 ci engine that was pretty much a rocket and got 20 mph, I’d say you were nuts. But here we are.
Old Jan 16, 2017 | 12:03 PM
redford's Avatar
redford
FTE Leadership Emeritus
Why stop there? Those pesky overhead valves should be eliminated also.
Old Jan 16, 2017 | 12:05 PM
99f350sd's Avatar
99f350sd
The engine has to come out of a same year or newer vehicle..to be legal epa crap..
especially if you have emissions inspections in your state.
Old Jan 16, 2017 | 05:52 PM
carpenterbug
Thanks.
Thank you for the responses. I only use it around the farm and to pick up materials in town. Fuel mileage, power and epa are not concerns. Just need less complicated maintenance on this vehicle.
I agree that the computer controlled/aassisted engines are here to stay. Even tractors are now computerized.
Old Jan 16, 2017 | 06:03 PM
EDC8008's Avatar
EDC8008
If it's what you really want then go for it. Simple wire from the on position to a resistor then to the coil on a breaker point system and you got spark. You'll need a low pressure fuel pump to supply the carb. To use the already installed you'll need a pressure regulator.
Old Jan 16, 2017 | 08:32 PM
carpenterbug
EDC8008, that is what I wanted to know although I did not know what ask. Your help is much appreciated.
live2hunt
1983 - 2012 Ranger & B-Series
Jun 11, 2007 12:46 PM
87beater
24
May 10, 2007 04:48 PM
swami
Mar 14, 2005 06:50 PM
tafrias
Mar 8, 2005 07:17 AM
liechtyj
Feb 29, 2000 09:20 AM
