Sponsored by: Real Truck
Starting problems
Old Jan 14, 2017 | 10:55 AM
Steveoweaveo's Avatar
Steveoweaveo
Starting problems
I have a 1999 f350 7.3. Turn the key lights and feul pump come on but the starter wont crank. I replaced the starter and checked all the fuses i could find. The only way i can get the truck to crank is by jumping the relay under the hood . thanks guys
Old Jan 14, 2017 | 11:37 AM
seville009's Avatar
seville009
Starter solenoid working?
Old Jan 15, 2017 | 08:39 AM
Steveoweaveo
Yes i replaced stsrter and starter cylenoid, ignition switch?
Old Jan 15, 2017 | 02:36 PM
D.Yaros's Avatar
D.Yaros
Just guessing here, but would not "jumping the relay under the hood" be a clue? Could the relay that is being jumped be bad?
Old Jan 16, 2017 | 12:15 AM
Steveoweaveo
R
its brand new also
Old Jan 16, 2017 | 12:37 PM
Mike1's Avatar
Mike1
Just because it's new doesn't mean it's good, but I'd recheck all the cables and wires.
Does it click when you turn the key?
Did you replace the battery terminals?
Did you check the cables underneath the rubber sheathing?
Clean all the grounds back to bare metal?
Recheck all connections?
Check fusable links?
Old Jan 17, 2017 | 07:25 AM
Steveoweaveo
thanks will start on all that today
Old Jan 17, 2017 | 12:33 PM
OneTon350's Avatar
OneTon350
If its an automatic, it might be the neutral safety switch.
Jiggle the shifter while turning the key.
Old Jan 17, 2017 | 06:11 PM
somehowford's Avatar
somehowford
I agree to check neutral safety switch. try starting the truck with the shifter in the 'N' position. if that works either the NSS is bad, or just needs adjusted. its mounted on slots so you can loosen the bolts and rotate it slightly. IIRC there is a line that must line up with shifter in NEUTRAL not in park. had this condition on several ford service trucks at my work.
Old Jan 17, 2017 | 06:41 PM
erikkloss's Avatar
erikkloss
If it is standard trans, there is a clutch pedal switch that is common to go bad.
Follmerpa
Jan 22, 2019 09:11 PM
Chris_stanworth
1983 - 2012 Ranger & B-Series
Jun 18, 2017 07:33 AM
hyper3199
1997 - 2003 F150
Dec 14, 2016 05:01 AM
belas
Jan 21, 2011 06:25 AM
moarkmike
Jul 28, 2010 04:58 PM
