Sponsored by: Real Truck
Cruise control problem
Old Jan 14, 2017 | 10:52 AM
Jer2014's Avatar
Jer2014
I have a 2000 f250 7.3 and the cruise control works when only when the engine is cold. Once the truck warms up, cruise will shut off and not reactivate. I have no lights on on the dash new clutch safety switch a new sensor on the master cylinder horn works and have had a scanner hooked up and compared the electrical values of the buttons pushed to the spec any help is appreciated
Old Jan 14, 2017 | 05:31 PM
projectSHO89's Avatar
projectSHO89
Did you use a Motorcraft or something else when you replaced the switch on the master cylinder?
Old Jan 16, 2017 | 06:16 AM
Jer2014's Avatar
Jer2014
Im fairly certain its a motorcraft switch but the original one that i took out wasnt leaking and had no other signs it wasnt working.
Old Jan 16, 2017 | 06:44 AM
projectSHO89
Go check your records and make sure, one way or the other.
Darrenkoke
6.7L Power Stroke Diesel
Jan 15, 2020 04:40 PM
Jkelley
Dec 11, 2012 10:50 AM
Agronomist
Feb 15, 2006 09:43 PM
BootHill
1978 - 1996 Big Bronco
May 21, 2004 06:06 PM
