Sponsored by: Real Truck
Cruise Control ?
Old Feb 8, 2006 | 07:55 AM
Agronomist's Avatar
Agronomist
Cruise Control ?
My cruise control will work sometimes (light on dash on/works perfect), then sometimes will not turn on (no light on dash/nothing). Any suggestions what wrong? Thanks...
Old Feb 8, 2006 | 09:30 AM
cokeman's Avatar
cokeman
Active Streak: 30 Days
Active Streak: 60 Days
Sounds like your switch is starting to go bad. Look on the end of your master cylinder for the switch with a couple of wires running into it. Check if it is leaking brake fluid. Search this forum, there is some good info on it here.
Old Feb 8, 2006 | 12:21 PM
Agronomist's Avatar
Agronomist
Will do.. Thanks
Old Feb 15, 2006 | 09:43 PM
Bigoom's Avatar
Bigoom
When your cruise control is not working, does your horn quit working too? If your horn quits also, then your electric cruise control located in the engine compartment is going bad or the connections are dirty.
