My thoughts on Bilstein shocks
Old Jan 13, 2017 | 03:49 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Well, I finally finished installing the Air Lift Ultimate 5000 (or whatever it is) and had the chance to really take the truck on an extended test drive.
So, I was headed down the road just enjoying the 75 degree weather we are having here in north GA and thought to myself, the truck feels really smooth. It then occurred to me that I hadn't really had the chance to really take the truck out for a test drive since installing the shocks.
The Bilstein 4600 HD shocks on my truck make a huge difference. The rear shocks appeared to be the original and 17 years old, the fronts were replaced at some point, but were no good either.
Don't get me wrong, it is still a truck, but it handles bumps and unevenness in the road surface so much better now.
I have a lot of pictures and video that I will do up as a how-to shortly, but for now I am going to enjoy my 32 degree SweetWater 420 ale and the sunshine...
Old Jan 13, 2017 | 05:03 PM
coax9952's Avatar
coax9952
Yeah, I've got them on mine too.....I'm not sure if it's just the rosy glow of having anything better than some ancient, leaky pieces of crap....But I love mine. The Airbags top it off nicely.
The old ones were kinda like standing on a destroyer in a hurricane, lotsa rolling, not much standing......
Old Jan 13, 2017 | 09:03 PM
ZachinCO's Avatar
ZachinCO
I put 5100's on my truck last year, replacing the stockers. Big difference, especially when I've got something hooked to it(bumper pull or gooseneck).
One thing I've noticed is that concrete roads seems to be more apt to create a rough ride. Blacktop/asphalt though is considerably smoother.
Old Jan 13, 2017 | 09:42 PM
coax9952's Avatar
coax9952
The 5100's are designed for The offroading crowd, So they are going to be a lot stiffer. My back can't stand much more buckboard rides, 30 years of driving Bucket trucks and no suspension took care of that..
Old Jan 13, 2017 | 09:52 PM
ZachinCO's Avatar
ZachinCO
Yeah, I knew going into it I'd have a stiffer ride, but sacrificed a little ride comfort unloaded so that the loaded ride was better.
Sounds like you worked for a utility....
Old Jan 14, 2017 | 10:20 AM
coax9952's Avatar
coax9952
Cable TV....The 8th foul word you can't mention on the air......
And I'm still doin it, at least for 3 or 4 more years. then I can start collecting some of that Gubmint Cheese!
Old Jan 14, 2017 | 02:13 PM
bigb56's Avatar
bigb56
I got Bilstein 4600's on the front a few years ago and noticed an improved ride and the truck just felt more solid and new on rough roads. Last week I put 4600's on the rear to replace what I think were the OEM's, can't say I noticed any difference there.
Old Jan 14, 2017 | 02:39 PM
coax9952's Avatar
coax9952
Probably won't until you get a load back there and notice the lack of Pogo stickin the a$$ end is doing.....
Old Jan 14, 2017 | 04:32 PM
timmyboy76's Avatar
timmyboy76
Ran 4600's for last 5yrs. Just switched to rancho 5000's. Whatta difference!, then again, new 4600's probably feel good too
Old Jan 15, 2017 | 10:51 AM
Bently_Coop's Avatar
Bently_Coop
I have Procomp ES9000's in the rear of mine and Bilstein 5100's up front including stabilizer. Truck was much improved over the blown shocks it had. I think the Procomp's are a bit soft and may get changed out later.
Sous- keep an eye on the front upper bushings, mine on the 5100's went out with in 25k, replaced with some ES bushings and all good now.
Timmy- I would think the Rancho 5000's would be light for a Super Duty application, either the 7000's or even adjustable 9000's would be a better fit.
Old Jan 15, 2017 | 11:05 AM
SRBF150's Avatar
SRBF150
I agree the Bilstein 5100's are great. I use them on the front and noticed a significant improvement as well. For the rear, I am also using the Air Lift bags but with Rancho 9000's which I will adjust from softest for empty driving to firmest when towing and that combo works great FWIW.
Old Jan 15, 2017 | 12:07 PM
timmyboy76's Avatar
timmyboy76
Crap! I knew about the 9000's, didn't know about 7000's. I plugged shocks into eBay and rancho 5000 came back at all 4 being 210.00std.
. I got airbags out bag, but 1 leaks. Will fix soon. Maybe that will help prolong them.
Old Jan 16, 2017 | 09:25 AM
Rancho Suspension's Avatar
Rancho Suspension
Former Vendor
If you are on a budget look to the 5000X. For the price point they are hard to beat, and are slightly gas charged and valved for this platform.
pi653
Nov 8, 2016 02:04 PM
351Cleveland C4
Apr 29, 2014 05:31 PM
TxFordGuy
27
Mar 16, 2012 02:41 PM
Johnny Langton
Apr 2, 2010 08:52 AM
Troglodyte
Jan 25, 2007 09:17 PM
