Injector Testing Facilities
Old Jan 16, 2017 | 10:54 AM
hotrodfeguy's Avatar
hotrodfeguy
I use a wire wheel in my bench grinder. The fine brush works great. I dont think I would ever use a scotch brite pad on anything I wasn't sure I had completely 100% clean after.
Old Oct 27, 2020 | 09:22 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Originally Posted by IDI-Charlie
Out of curiosity, does anybody know if shimming an injector would cause a rebuilder to not accept it as a core, or am I over-thinking things?
Some "rebuilders" still use shims as they don't have the correct equipment or possibly they decide they don't want to spend the time on machining.
Old Oct 27, 2020 | 02:50 PM
AubieTN's Avatar
AubieTN
IDI-Charlie, not sure of your 20, but I have heard on their local advertising that “Diesel Plus” in Ringold, GA can test the 7.3 injectors along with other brands. Just Google them and give a call. One of the co-owners is Mike Perkins (Doctor Diesel); he and I at one time worked for the same company. He also is the diesel co-host on a Saturday morning radio car question/answer program.
Old Oct 27, 2020 | 04:17 PM
FinnishStroker's Avatar
FinnishStroker
Ok,im feeling funny today..🤡
Its been 3 years and i think Charlie has found a place to test his injectors..😉
Seriously,good info of course added to the topic! 👍
Old Oct 27, 2020 | 06:22 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I'm wondering why ressurecting a nearly 4 year old thread in an effort to slam other injector rebuilders is "good information".
Old Oct 27, 2020 | 06:45 PM
Bitterroot Diesel
Former Vendor
Maybe, so many times we never hear the ending to a thread 🤣
Old Oct 28, 2020 | 12:44 AM
FinnishStroker
I meaned AubieTNs answer as an good info added to the topic.It clearly points a place to test out HEUI injectors..
cleatus12r
Tried to PM you,but can not..
Can you hit me A PM that I can answer,i have something to say to you.
Old Oct 28, 2020 | 03:24 AM
IDI-Charlie's Avatar
IDI-Charlie
Man what a blast from the past, forgot about this thread.
Never sent them off to get tested actually. Ended up going with new injectors in the long run. They had about 371k when I swapped them, they lived a good life.
Correct. This one never really reached a resolution on facilities, so it was never updated at the time. Shortly after this I got the two in question swapped under warranty, and went to 160/80s about 35k miles ago.
Definitely good to know. If I ever need some tested in the future I will be sure to give them a ring - appreciate the heads up!
Old Oct 28, 2020 | 08:14 AM
SkySkiJason's Avatar
SkySkiJason
Not all ‘injector testing’ is the same.
The variables include ICP, testing fluids, fluid temperature, accuracy of measurement, the ability to make accurate adjustments, etc. It’s also worth noting that ‘injector balance’ can be skewed by the number of cycles in the test (more cycles exposes greater differences). Some builders advertising minimum % deltas could be using limited cycles so they don’t exceed their advertised balance.
I think it is Bitterroot’s goal to provide the most accurate and most real-world testing on the market. From what I can tell, the other’s are either not using the specified HEUI ‘calibration fluid’, testing with ‘cold’ fluid and injectors, not using operating condition ICP are using primitive measuring methods, etc.
I will also say if you read the fine print in the advertising for other builders, you can see wiggle room in their claim of ‘all new parts’ being used.
I have personally been burned by most of the popular 7.3 injector builders. Unlike a guy putting injectors in his truck in the driveway, I have been paid to install injectors for others. When the injectors that I recommended don’t work right, I don’t charge my customer/friend to swap the garbage out. I feel like most of these guys started out building decent injectors and gradually cut back on quality to improve their margins. It is refreshing to see a company that truly puts their heart in their product and would rather sell nothing that put out a bad product.
vermilian
Nov 12, 2014 12:03 PM
ltl_jrw
Jun 27, 2011 11:29 PM
suzuki_vinson
Nov 1, 2008 10:13 AM
ecsmith0624
1978 - 1996 Big Bronco
Nov 21, 2003 07:51 PM
