Help!!
Old Jan 11, 2017 | 09:09 PM
Biggpoppa76's Avatar
Biggpoppa76
Help!!
Ok I've tried to research this and I need help bad. I currently on a 95 F150 4wd 5.0. It has 3 265/75-15's and one 31 10.50 on front. The reason for that is my other 265 went down and this was the only option I had. Money is tight! I work on a strip mine in eastern Ky. So I have to have a 4wd to get to work. I know that running it in 4wd on hardtop will destroy it. But here's my question. I know that a 31 10.50 is .33 inches larger than my 265's. with that little of a difference can or will it hurt my baby?
Old Jan 11, 2017 | 09:30 PM
88n94's Avatar
88n94
Are you saying the difference in diameter is .33 inches? 1/3 of an inch? That is probably less than the difference between different tire brands of the same size.
Old Jan 12, 2017 | 08:09 PM
*2fords*'s Avatar
*2fords*
You have an open differential, so power is only going to one wheel anyway, so it's not going to hurt anything.
Now if you had a locker in the front where power was going to both wheels, then a big diameter difference could matter, but being only 1/3 of an inch not a problem.
Old Jan 13, 2017 | 01:40 AM
Rollingscrapmetal's Avatar
Rollingscrapmetal
Eventually it will cause a wear issue being as the open diff is only meant for intermittent use
dh_meyer
2009 - 2014 F150
Feb 8, 2016 07:44 AM
kirkules
Apr 23, 2014 02:20 PM
Northguy
1997 - 2003 F150
Jul 9, 2004 08:37 AM
fordeverpower
Jan 30, 2004 10:23 PM
Rick two
1997 - 2003 F150
Jun 13, 2003 08:26 AM
